drive gear/driven gear questions
This is a discussion on drive gear/driven gear questions within the Technical forums, part of the Caferacer.net Forums category; so, if im replacing my rear wheel and drive gear(to a larger sprocket)... should i also replace my driven? im jumping from a 36t to ...
Results 1 to 10 of 11
    Feb 2009
    austin, texas, .
    im jumping from a 36t to a 45, and changing my chain too of course.
    honk if youre horny.
    Member overdraft's Avatar
    May 2009
    victoria, bc, Canada.
    it's always recommended to change the pair at the same time... that's the conventional wisdom. that said, if the front sprocket is in good shape and showing no sign of wear you could just do the rear. considerations are things like, how much is the new front sprocket... if it's $15 and you're not sure if it's in fine shape then it might be a good investment to go along with your $100 chain and $80 rear (i'm making up prices to illustrate the point) or if your rear is showing slight wear but it's aluminum and your front sprocket is steel, then again, you might just get the rear. unless the front is reeeeeally pooched the only real issue is how much faster you'll wear out the other components. you pay now or you pay later! you can only defer maintenance, you can never avoid it!
    1970 CB350K2
    Aug 2006
    Portland, Oregon, USA.
    that's a massive jump in tooth count. What the heck would you large for? If you don't raise the tooth count up front you'll end up with a quick blast 0-30mph or so then nothing......
    Again...why such a massive difference?
    ~Albert Einstein
    Feb 2009
    austin, texas, .
    its the gear that came with the rear wheel i bought,much better shape than my current one. also the current sprocket wont fit as im putting a kawasaki wheel on a honda.
    Aug 2006
    You're gonna want to get a more suitable rear sprocket amigo.......seriously.
    ~Albert Einstein
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    do you even know if the chain is the same???
    Feb 2009
    austin, texas, .
    the chain isnt the same, had to buy a new one and take a few links out.
    i dont know where to find a smaller sprocket for a kawa wheel from the seventies before i go to work tomorrow... so i'll have to ride this set up til atleast the weekend.
    whats the main problem with a sprocket that size? my kawasaki kz 400 has the same rear wheel set up...
    Senior Member Victor52b's Avatar
    Feb 2009
    Eastford, CT, Sri Lanka.
    You won't need to use first gear.
    Guessing that the (honda) gearbox sprocket is around 16 teeth, the 36T rear sprocket gives a 2.25:1 ratio. The 45T rear gives a 2.81:1 ratio, or about 20% different. That means that your rear wheel will go around 20% slower with the 45T rear sprocket. So, first gear will become irrelevant, and top gear will be winding out 20% sooner (at somewhere around 70 mph). Good scrambles set up.
    I'm guessing that the KZ400 comes with a much larger gearbox sprocket.
    Feb 2009
    austin, texas, .
    damn, well maybe i can pull the sprocket out of the kz for the time being. what would be a better size to run with a 45t???
    Feb 2009
    A 20T gearbox sprocket would you give the same ratio... if it will physically fit in the space at the gearbox, and if your present gearbox sprocket is indeed 16T.
  1. honda brake identification and drive gear needed
    By joe1028 in forum Technical
    Last Post: 06-26-2012, 08:15 PM
  2. gear
    By raven in forum General
    Last Post: 09-17-2010, 09:52 AM
  3. i need mx gear
    By joe c in forum General
    Last Post: 08-08-2008, 07:57 PM
  4. Gear Ratios
    By aaron in forum Technical
    Last Post: 10-29-2004, 09:01 PM
  5. cb 350 speedo gear
    By musk-rat in forum General
    Last Post: 12-29-2003, 05:18 PM
