Swapping rear rim?
Swapping rear rim?
This is a discussion on Swapping rear rim? within the Technical forums, part of the Caferacer.net Forums category; I have a cm400e and was wondering if it would be possible to swap the rear rim out with a 18" cb550 rear wheel. The ...
Results 1 to 2 of 2
    smahala1286's Avatar
    May 2009
    Swapping rear rim?
    I have a cm400e and was wondering if it would be possible to swap the rear rim out with a 18" cb550 rear wheel. The CB wheel has a 120/90 tire on it. I don't know if it will be to big to use with the front 18" wheel, it might look goofy. What size front tire would you recommend?
    Sep 2008
    , , Mongolia.
    i have no idea. but wouldnt mind some pics of how it looks if you do it.
    j
  1. Swapping CDI boxes
    By whiskeysid in forum Technical
    Last Post: 12-04-2012, 06:29 PM
  2. Replies: 2
    Last Post: 04-23-2012, 07:47 PM
  3. Swapping tubes for cb450
    By Pluto in forum Technical
    Last Post: 02-18-2012, 10:15 AM
  4. Swapping drum brakes
    By Weston66 in forum Technical
    Last Post: 07-13-2011, 04:36 PM
  5. tank swapping
    By StormShadow in forum Technical
    Last Post: 12-07-2010, 02:30 AM
