How hot is hot?
It will be over 220~350f around exhaust side of cylinder head, the cases will get over 175~190f.
It's probably condensation evaporating off now weather has got a bit warmer.
PJ
This is a discussion on 2 questions about a cb350 within the Technical forums, part of the Caferacer.net Forums category; #1 Why the hell is my motor so HOT...I mean I know they they get hot but I'm sure mine is running a bit too ...
#1 Why the hell is my motor so HOT...I mean I know they they get hot but I'm sure mine is running a bit too hot. Oil is fine, timing is on...not sure what it could be.
#2 Noticed a little bit of smoke coming from the breather hole on top of the valve cover. What the hell is up with that....just started yesterday. I don't have an actual breather tube attached...as i have pods.
Thanks guys, Tim
How hot is hot?
PJ
How hot is hot?
PJ
like REAL HOT...both points covers get really hot, as well as the crank cases.
Maybe trying a different oil? Synthetic, 10w-30 as opposed to 40 weight?
go get an infrared thermometer. I don't think they are that expensive.
http://www.sears.com/shc/s/p_10153_1...rd=thermometer
you can probably borrow a pro-grade one from any place that does tool rental.
or you can go get an old fashoned meat therometer and drop it in the oil after a hard ride - much cheaper. If you are seeing 300 degrees or more in the oil then yes there is something wrong.
typically an overheating aircooled bike will begin to "run funny", detonating and such.
- Samuel BeckettA tool is just an opportunity with a handle
I'll try it tomorrow!
Now, what about the smoking from the valve cover where the breather tube is supposed to be?
depends on how much smoke we are talking about.
