12v dc power, what line to tap into?
This is a discussion on 12v dc power, what line to tap into? within the Technical forums, part of the Caferacer.net Forums category; i know youre all tired of me posting things about the acewell i bought... im tired of it taking so long to hook up! i ...
Results 1 to 10 of 12
    Feb 2009
    austin, texas, .
    i got it to power on only when it was in park. so, that doesnt do me any good.
    what wire would you/have you cut into to power your digital nonsense?
    i just want it to atleast power on when it should so i can go from there.
    honk if youre horny.
    Senior Member pampadori's Avatar
    May 2007
    Richmond, Va., USA.
    why are you putting your bike in "park"?
    do you have a test light? you need to use a test light and probe a wire that turns on the test light when you have the key set to on only. test lights are like $9 from radio shack or make your own with a 12v bulb and some wire. or better yet, use a volt meter.
    http://www.slingshotcycles.com
    Stainless braided brake lines and other odds and ends.
    Enter coupon code "caferacer" during checkout for 15% off
    May 2007
    Richmond, Va., USA.
    Feb 2009
    austin, texas, .
    my ignition switch has three settings, in ''on'' the acewell doesnt turn on but when you turn the key to park...it does.
    Feb 2009
    austin, texas, .
    There should be a larger diameter wire off the ignition switch that is live all the time. Use this for your "live" wire (clock). Either that, or run a new wire straight from the +ve terminal on the battery (probably put an in-line fuse on that).
    As far as the "on" setting goes, you'll need to find the return from your ignition switch. Usually it's either red or brown.
    Feb 2009
    austin, texas, .
    i run a yuasa mini battery thats like 4ah... should i really bother using the clock? i wouldnt want to run down the battery.
    The clock is just an LCD - it would take about 2 years to run your battery down.
    Feb 2009
    austin, texas, .
    well sir, that sounds like a risk im not willing to take.
    kidding.
  1. more power
    By patlschr in forum Technical
    Last Post: 03-22-2011, 12:18 PM
  2. Power from coils...
    Last Post: 09-28-2010, 05:53 PM
  3. Seems way out of line
    By magnetoczar in forum General
    Last Post: 02-23-2010, 11:37 PM
  4. power wheelie!!!
    By coreyjdl in forum General
    Last Post: 12-10-2008, 12:15 PM
  5. I Have No Power
    By sxecafe in forum Technical
    Last Post: 06-27-2008, 04:59 PM
tap into a 12v electrical line
what is a dc nine tap
