Here is some pics of my 75' CB200T, When I picked her up she started but ran poorly. Here is what was wrong, She wouldn't idle, the electric start would not work, took 5 or more kicks to start, would hesitate at about 5500 rpm Wot. After running for a while would not start up again. So I started by replacing the battery and spark plugs, then the points were re-gapped, oil changed, carbs taken apart and cleaned, timing set. Now it starts first kick and with electric start, she idles at 1300 rpm all day long, the only thing is she hesitates at about 7500 rpm's now. I am going to re-build both carbs and see if that helps. Well after that novel here she is..... well after trying to add a pic for about 15 minutes I give up, some help would be greatly appreciated. Here is a hyperlink from photobucket http://s281.photobucket.com/albums/kk218/hinorona/?action=view¤t=P1000517.jpg
Thanks
Eric
Thanks
Eric
