ya think? View attachment 106983
Well do I just get new carbs or something because I’m kinda lost nowya think? View attachment 106983
You can’t swap around them since they sit on a bracket the connects them all togetherIf it was only one carb you should have trouble-tested that by now by swapping them around.
Yeah it already has a 4 into 1 exhaust on it, I plan on getting a set of Murray’s carbs at some point but I’m gonna try and get these ones to work in the meantimeYou can’t swap around them since they sit on a bracket the connects them all together
How many parts on #4 carb are Not interchangeable with the parts on one of the other 3 carbs? Suzuki doesn't build the carbs, they buy them and it would become costly to order them all significantly different, they generally avoid that. I suspect you just need to try harder, or you might better start shopping for replacements, but sets of 4 carburetors at a time is going to get expensive real fast, new or used. New carbs are very costly and used carbs will need just as much repair service as your old ones did.You can’t swap around them since they sit on a bracket the connects them all together
Yeah all the parts are interchangeable but there’s this bracket type thing on the back that holds all four together so can’t exactly swap carbs but I can swap parts aroundHow many parts on #4 carb are Not interchangeable with the parts on one of the other 3 carbs? Suzuki doesn't build the carbs, they buy them and it would become costly to order them all significantly different, they generally avoid that. I suspect you just need to try harder, or you might better start shopping for replacements, but sets of 4 carburetors at a time is going to get expensive real fast, new or used. New carbs are very costly and used carbs will need just as much repair service as your old ones did.
You're still lucky the originals are not CV carbs, that would have made it even more complicated, the ones you are working with are relatively simple.best luck getting it firing on all cylinders
They are different. The passages are drilled so the adjustments face outward. And 2 & 3 have the fill pipe drilled all the way through, where as 1 & 4 have the fill pipe on one side facing inward. #1 is the only one that has the mount for the choke lever, #3 has the port for the fuel tap, etc. There are other differences, too. You can’t just swap carb bodies aroundHow many parts on #4 carb are Not interchangeable with the parts on one of the other 3 carbs? Suzuki doesn't build the carbs, they buy them and it would become costly to order them all significantly different, they generally avoid that.
While you can’t swap the carb bodies around, you absolutely should take them off the bracket to clean them thoroughly. You have to clean ALL the ports and passagesYeah all the parts are interchangeable but there’s this bracket type thing on the back that holds all four together so can’t exactly swap carbs but I can swap parts around
That’s exactly what I plan on doing once I have the time to do itWhile you can’t swap the carb bodies around, you absolutely should take them off the bracket to clean them thoroughly. You have to clean ALL the ports and passages
Must be why they came up with those strange double barrel setups on the later models.They are different. The passages are drilled so the adjustments face outward. And 2 & 3 have the fill pipe drilled all the way through, where as 1 & 4 have the fill pipe on one side facing inward. #1 is the only one that has the mount for the choke lever, #3 has the port for the fuel tap, etc. There are other differences, too. You can’t just swap carb bodies around
most inline 4 cylinder carb banks are the same way. Tha way gas fills the bowls, alone, means 1 & 4 are unique. 2&3 might be able to be swapped on some bikes, but the air screws would be on the wrong side usually,Must be why they came up with those strange double barrel setups on the later models.
Maybe why I stopped riding Suzuki when they stopped building 2-strokes too.
UsuallyTrialsRider, the accelerator pump (usually on #2) is for acceleration, the air cut valve is to prevent after-fire on deceleration and is 'automatically' operated by intake vacuum
