21 - 40 of 77 Posts
Mikuni carbs have excellent service documentation online free, sudco is a company name sometimes associated. The float height is specified in the motorcycles service manual because it is determined by the angle the carbs set on the bike as much as anything else. Usually very close to half way through the floats limit of travel it should stop flow of fuel.
Float level is critical because it makes a thing called the emulsion tube work well or not. The emulsion tube introduces bubbles into the fuel and starts the fuel atomization process.
1982 kz440a
He said it leaks while "running" that indicates that the petcock is only flowing while vacuum is applied therefore working properly. Dont go tearing the carbs apart again just yet, The problem may be much simpler. Remove the drain screws and inspect the tips. If they look like this:
Body jewelry Finger Wood Thumb Jewellery
Chuck them in a drill and spin them on a file until they seal properly. I suspect this is your problem because if the floats were too high you'd be complaining about your cylinders flooding and other poor running issues.
1977 Suzuki GS750
Discussion Starter · #23 ·
He said it leaks while "running" that indicates that the petcock is only flowing while vacuum is applied therefore working properly. Dont go tearing the carbs apart again just yet, The problem may be much simpler. Remove the drain screws and inspect the tips. If they look like this: View attachment 106756
How will I know when I should stop filing them so they seal properly before putting them back on the carbs
Somewhere there's a guy who had to determine the tolerances for that part. And there's someone else who had to test things to make sure they worked. And someone else who had to determine the capability of the process to manufacture the part to those tolerances. And someone else who had to check to make sure the finished part met the numbers on the drawing.
And then there's the guy who puts it in a drill and files it until it looks right.
Not criticising, do whatever works. I just find it funny (having been the guy who had to develop/check tolerances on things for a lot of years)
1982 kz440a
The tolerance on a drain screw is not critical. It's threaded, and it's soft. So as long as it's circumference is fairly uniform.... it will seal.
So I finally have the time to do it now and where is the drain screw you’re talking about because the one on the bottom of the bowl looks nothing like that
Determine the model # of your carburetors and then google up a part list and/or exploded diagram of that make & model carburetor. That is how you find out what is in there without even taking it apart. :geek:
1977 Suzuki GS750
Discussion Starter · #34 ·
My money is on something causing the float needle not to seat. does fuel overflow out of all carbs or just one?
... could the gas be coming out of the tank to quickly
That's what the carburetor float valve is for. It needs to seal off the flow and regulate it at the correct height, just like a toilet tank. It can do that because there is such a small opening the needle valve takes very little force to close off the flow and that force is flotation of the floats. It also takes very little dirt to plug a needle valve or make it leak, it needs to run clean fuel.
1977 Suzuki GS750
Discussion Starter · #39 ·
I’m gonna take them apart and clean them again and put a fuel filter in
I also plan on taking the bike to a shop on Saturday
I highly recommend ultrasonically cleaning them
21 - 40 of 77 Posts
