So I haven’t done that yet but it doesn’t leak now and startsYou're also going to want to service the valve shims
the problem now is it sputters after 3000-4000 rpm
Carb Kit - 1977-1979 Suzuki GS750That's about the rpm where your ignition spark advance begins to do something hopefully, but it's also the revs where the carburetor main jets start to make a major difference. You need to determine if it's electric or carburetor related and that's not easy when both are going to mess up a plug read.
I had the same problem with my gs and eventually wound up buying a intake and carb kit from murray carbs. They sell 2 intakes that connect 2 34mm mikunis and the performance was amazing.Carb Kit - 1977-1979 Suzuki GS750
That’s the rebuild kit I got and I also got floats too
It could be both now but it ran completely fine when first put the kit on the bike but now it’s giving me problems so it could possibly be a electrical problem
Do you have a link to themI had the same problem with my gs and eventually wound up buying a intake and carb kit from murray carbs. They sell 2 intakes that connect 2 34mm mikunis and the performance was amazing.
So did you loose any power on the bike
I gained low end torque after I jetted itSo did you loose any power on the bike
Sounds good to me, I wish it wasn’t super expensive thoughI gained low end torque after I jetted it
Yea it breaks the bank but it looks great and performsSounds good to me, I wish it wasn’t super expensive though
Well I’ll have to try that if it comes down to itYea it breaks the bank but it looks great and performs
Gotya . Good luck broWell I’ll have to try that if it comes down to it
Is this the same engine you are trying to sell now?I had the same problem with my gs and eventually wound up buying a intake and carb kit from murray carbs. They sell 2 intakes that connect 2 34mm mikunis and the performance was amazing.
I had it on the bike then had it on a gokart then rebuilt it and now selling itIs this the same engine you are trying to sell now?
If it is then how do you know it performs amazing![]()
How much for the carbsI had it on the bike then had it on a gokart then rebuilt it and now selling it
