Looking forward to future updates.
Thanks for the advice.You have got the makings for a very nice vintage superbike. The one glaring issue for me is that hideous seat. It also looks like the rear cowl sits too far back behind the rear edge of the rear wheel. I would shorten the whole thin until the end of the seat cowl is even with the back edge of the rear tire. Then reupholster the shortened seat pan to look right with the tank and rear cowl. The yellow with black number plates are novice colors for club racing. If you are going to run number plates then do it with white plates and a black 34 on them. Google images will give you some ideas.
There's a recess in the tank for the o-rings. The rubber gasket will cover the whole aluminum plate and the whole thing should sit flush. That said, yes, I am going to replace the whole thing... Probably with a pingel set up.Jeez - dodgy fuel tap conversion.
Aren't your bolt o rings going to hold the plate off the tank and not let it seal? I'd just be getting another fuel tap from China off eBay. Most fuel taps have the same bolt spacings.
That's the colors required for Sportsman classes in AHRMA...The yellow with black number plates are novice colors for club racing.
True, but the GS750 would be a vintage superbike in AHRMA and that requires green plates. If that was raced it would have been with WERA, CCS, CRMA or CRA but most likely MRA if it was a MO bike. All of those Orgs have yellow and black as novice plates. I have raced with all of them and AHRMA, except CMRA.That's the colors required for Sportsman classes in AHRMA...
theres a what? Thats a hole which they put a weldnut over to attach the tap. I'd be a tad upset if you developed a groovy new way to jihad a suzi four pot by giving it a leak source of raw petrol above hot things that make for flat black paintjobs with no discernible plastic parts left on the bike.There's a recess in the tank for the o-rings.
Wholly Hell!More GS750E builds I say.
It sure beats dealing with bored young idiots or CB350's with the tire rubbing on the frame loop.
Danger, is my business."
appreciate it, I had interpreted the layout as the 6's went between the tank and the bracket, not the screw and the bracket.number four does all your upper sealing and a pair of number sixes take care of anything that wicks down the threads. I've seen fibre, copper, and alloy all used in the material of said washer and they're under the tap so that number 4 gets a clean flat unobstructed shot at sealing the top half of it.
Not saying your plan won't work, but if i have the choice of trying to reinvent the wheel, or becoming a fireball, i'm pretty happy with wheels as they are.
Good info, thanx.True, but the GS750 would be a vintage superbike in AHRMA and that requires green plates. If that was raced it would have been with WERA, CCS, CRMA or CRA but most likely MRA if it was a MO bike. All of those Orgs have yellow and black as novice plates. I have raced with all of them and AHRMA, except CMRA.
