41 - 60 of 70 Posts
Discussion Starter #41
The Carona weekends roll on and.........Ok, so, shit's gettin real......
As this is my first TOP END REBUILD I decided to take the engine out so I could do all the work on a bench.
103129
There's a fair bit of oily gunk on the fins below the head gasket, so it's possible that's blown and a cause of the low compression.......but I suppose we'll find out wont we.
And.....well, once the engine's out there's not much left is there, so the WHOLE thing is getting stripped down so the frame can get painted and other parts cleaned, polished, painted where necessary, re-greased and put back together. Worms, meet Can. :) hahahaha
103131
When I first started thinking of this project, I was always going to leave the frame WHITE.......then I had ideas about BLACK, but I've come around to WHITE again. Too much black can be too much, y'know. I found this image in my photo bucket that was one of the first to inspire me to create something with the old XR. I've read some really bad reviews on the build of this bike, but I love it........The white frame, the Red Tank, the black rims and engine.....I just thought it would also fit so nicely with the HONDA brand. So THIS is the look I hope she'll emulate.
103130
But at this stage she just looks like this.....haha
103132
So, there's a "little" bit of work to do before it looks anything like the Husky. ;)
Yep, right now she's just a frame with the Fork attached.
That'll come off soon and the frame will get some attention, clean up welds and respray white :).
I'm thinking I might even pull the rims apart and polish the black hubs to get them as clean as possible, respray if needed then either polish the Ali rims or paint them black and re-lace. IF the engine rebuild goes ok, I might spring for a new set of front and rear Black Rims and re-lace them onto the existing hubs? (Pretty sure that's possible) We'll see.
Suspension bearings will be checked, cleaned and re-greased wherever possible. Rest of the ALI Bits will get polished and re-installed after cleaning.
And yes, I'm SERIOUSLY considering painting the engine Black & Polishing those beautiful Air Cool fins too.
Discussion Starter #42
So, the engine is out, the Top is off
103165
103166
and I'm trying to get the Cam Chain Tensioner loosened to remove the Cam Chain off the Cam Gear......As per these instructions in the manual.....
103167
How f&%ken difficult do you think it is to get a set of pliers to Grab that little wedgy bit???
103168
Nearly Bloody Impossible is how difficult! (grrr). Just not enough meat to get any purchase and lifting that thing is a bugger. You can see from the photo how the edges of the chamfered bit are getting chewed by the pliers slipping off.......
SO, I spoke to a mate who said, "You're gonna have to pull the clutch anyway, just release the tension from the bottom...."
So off came the R/H side.....
103169
Annnnnnnd then we come to the most RIDICULOUS piece of engineering I've come across in my entire 8 week career as a motorcycle mechanic......
Yes, Ladies and Gentlemen, Present to you, the HONDA Clutch Basket Nut.
103171
Hard enough to get off at the best of times, but with the added wisdom of making it some crazy "4 Pronged Round Nut Thingy". Too much Saki the day the Nippon Team designed this one. haha. ;)
Anyway, the Nut removal tool is on it's way.......
I could use a Brass Drift, so I've been told, but I don't have one, and the nut removal socket is only AUD$15, cheaper than a brass drift. So I'll wait.
The BIG CHALLENGE is how to stop the Clutch Centre from Turning......
There's no Gear to wedge anything against on the R/H Side?
So, based on some videos I've seen of people doing this with the engine still ON the bike (yes, I'm a FOOL for removing the donk) I'm planning on putting it in 6th Gear, bringing out my trusty, shit covered Plumbing Stilsons, and Grabbing the Front Sprocket on the L/H side to crack the nut.......
If anyone has a better idea and can explain it well, I'd love to hear it.
Wish me luck. :LOL: ;)
I'm pretty sure there is an easier way to stop the gears on the clutch basket from turning :/
what happens if you start to engage the kick start gear, does that stop the clutch from turning backwards?
Alternatively refer to the shop service manual to see if there is a special tool to do the job and improvise something based on the same principal.
Wish I could be of more help, best luck.
If it helps any, you are doing things the right way, most noobies would have powder coated the frame and engine and purchased a stupid amount of aftermarket crap before they even got the motor sorted.
Discussion Starter #45
Thanks Trials Rider, I was really having fun until this little bastard reared it's ugly head....haha.
Tight as a Nuns Nasty.......scuse the french.
I've read all sorts of stuff about wedging timber or a nickel into a gear somewhere, but I can't see anywhere obvious to do that, and I don't want to break anything by doing something stoopid. (i've already bent one bolt the Stilsons were pushing up against while holding the front sprocket. No biggy, but I don't wanna break something big)
If anyone has a concise explanation of how to stop the internal clutch bit from spinning, so I can undo this nut, I'll be very appreciative! :)
If you have an impact wrench, the nut will come right off.
Thanks Upperb.
I do have an impact wrench and have received the clutch nut 4 prong removal tool, but my problem, as above, is that the clutch just spins.
Are you saying the nut will come off with an impact wrench, WITHOUT stopping that thing from spinning?
Discussion Starter #46 (Edited)
HOLY SHITBALLS! UpperB, You're a bloody Genius! (y):love:(y)
Impact Wrench, braaap braaap braaap, and OFF SHE COMES. No holding the centre clutch or front sprocket required......
In the words of some famous dude......"Well, that was easy?"
CHAMPION! Thank you Sir!
Discussion Starter #47 (Edited)
Ok, so, with a follow up thanks to UpperB and this little beauty....
103175
The clutch nut was removed in a flash (after much previously unnecessary swearing & general breaking of shit trying to do it with a socket)
And the Cam Chain Tensioner Removed.......(Either someone has shortened my tensioner or the Manual is Rubbish......there's simply NO WAY you can push that wedgy bit up far enough to slide a paper clip underneath. Even with the tensioner fully compressed, that wedgy bit wont come up far enough. Slide a paper clip under?....Rubbish.)
103180
Cam is out and from my highly experienced trained eye, the lobes look ok......?
103181
And Head is.......OFF! :)
103176
I'm assuming that if the head gasket was doing it's job 100%, then the whole face of that joining surface would be clean.....like the L/H side.......not dark and carbon (or oil?) deposited like the R/H side? Anyway, unless the cylinder is toast, I think this part will be the only part I send away to get done in a shop. I keep thinking how my missus is going to react when I tell her I'm going up the road to get a Head Job. :ROFLMAO:
And this is what the top of the cylinder looks like....
103177
The cylinder itself......
103178
A mate I've shown these photo's to suggested it looks "Ok", might just need a hone," but that it needs physical inspection to be sure....So, fingers crossed.
The piston is a Wiseco 77mm jobby. 4466MO7700
So, if it does end up just being Head Job (yay for head jobs!), Rings and Hone, my mate reckons technically we should HONE and then measure to see whether the 3032X ring set for this piston will still suit???
103179
Lots of black burnt stuff. Burning oil?
Next step, take the cylinder off and inspect the piston..........
Stay tuned. :p
Piston rings can become gummed up with carbon and combustion residue resulting in a poor seal. Physical cleaning of the parts and reassembly can sometimes correct that situation with no replacement parts actually required, I had that happen once. You can still see the affect of the previous hone on that barrel but I see no scars from the piston travel, that is a good indication.
Is your service an Original Equipment Manufacturer shop manual or one of those re-write ones by a third party? The third party ones are useless if you have an OEM service manual, sometimes they are even inaccurate and/or misleading.
Crankcase ventilation: You will see a lot of people come through this place where they have removed the air box and stuck a tiny pod filter on the crankcase breather. Those people are idiots because the filter becomes plugged and now their crankcase is turned into a pump.
A single cylinder engine that has a piston displacement of 250cc moves 250cc with of dirty oily air in and out through the crankcase breather on every stroke. That's a Lot of high speed air movement. Added to that is pressure from blow-by. Blow by exists even on a brand new motor.
Consider TrialsRider’s remarks carefully. It is, as he makes clear, important to keep crankcase pressure low, to achieve the most power (it robs power to compress crankcase air) and to minimize “blow-by” of oil from the crankcase, past the rings and into the combustion chamber. Drawing a negative pressure by routing the breather to the airbox helps in this regard, instead of routing it to atmospheric pressure or sticking a filter on the crankcase port (increasing crankcase pressure in the process).
Remove the rings from the piston and clean everything. DO NOT run a hone in the cylinder unless and until you decide that you will be replacing the piston rings. And if you do hone the cylinder, do so only after you have confirmed with the ring manufacturer, the correct grit hone to be used.
After you clean everything, you need to take some measurements. Do you have inside and outside micrometers? Are you comfortable with using them and confident that your readings are accurate? If not, a local machine shop or auto or motorcycle shop would probably measure the piston and the cylinder for you for free or for a couple bucks. Look in your service manual for specifications for each. Remember that the greatest cylinder wear occurs near the top, where the top ring is forced against the cylinder wall at high pressure, during combustion.
Discussion Starter #51
Thanks Trials Rider....
Yeah, my service Manual is a Haynes one, bought it when I bought the bike in 97-98. It is kinda confusing sometimes.....
Here's a couple of better photos of the piston and barrel.....
Some vertical lines on the barrel, but FEELS smooth as a baby's bum. Can't feel anything with fingernail.....nothing, so the photo might make it look worse than it is....
103190
The piston itself looks good. Also some small vertical marks on the horizontal lines above the rings, but looks in pretty good shape?
103191
My crank case breather was just vented to AIR via this tubing. Top wasn't connected to anything and bottom the same, just vented out the bottom near the swingarm..... My intention was to just hook it back up as it was?
103192
Thanks UpperB...
Good advice. I am taking the head to Greg Ball Engineering (comes highly recommended from a few of my friends) so they can do the Valve and head service work. They've already offered to have a quick look at the piston and barrel, so that'll be good to have some confirmation there.
I have some analog vernier calipers that I'm comfortable with, but they obviously aren't as accurate as a micrometer. It'll give me a sense of where we're at though.....
Will update after I've taken the bit up to the shop...
Thanks again!
Just use a pair of inside callipers, you don't even need the measure to measure wear if there was any since last over-bore
set them to gently fit the top of the cylinder above where the piston rings travel, if it is that big all the way down you are good to go.
, there has to be a way to see if the valves hold pressure, if they do that should also be good to go, ;) get creative, will save you on the valve job if it's not needed. stick an air valve stem in the spark plug hole, bolt a flat plate on the head where the compression ring is and see if it holds air pressure lol
Discussion Starter #53
Thanks TrialsRider..... The guys up at Greg Ball Engineering are supposed to be top notch, so, I'll take the head up there and see what they say, both job and cost wise before I get the gas ax out and start creating the head pressure tester contraption you're talking about.....haha. thanks mate. (y)
Discussion Starter #54 (Edited)
The head is up at the Shop, still waiting on the diagnosis, so keeping fingers crossed it's all going to be sweet.
So, I took the time yesterday to settle into the garage with some rags and brass brushes, a tub of Turps, and Roy and HG Bludging on the Blind Side, then Grandstand on the ABC (Can't WAIT for the footy to come back) and start cleaning up some of the parts that'll be thrown back on the bike soon enough.........
Mainly the suspension and linkages. They were filthy.
103230
Now they're not....
103231
There's the usual scuffs and scratches you'd expect on a 30y.o dirtbike swingarm, but that's no problem. I'll polish them out as best I can and that's it.
The frame got an initial clean today as well, in prep for paint, but it'll get more before the paint is actually applied. Waiting on Seat Loop to arrive. :)
On a side note, I rode my KTM last weekend and had one rocky tip over that saw this "Burst into Tears Worthy" dint in the Header Pipe. Ok, I'll admit it, I might have cried and swore at the same time when I saw it.....
Sensitive content, not recommended for those under 18 Show Content
103232
(If you're seeing a sensitive content warning about the above picture, I'm not sure why, it truly is just a picture of my dinted header pipe. Certainly doesn't look like any vagina I've seen? hahaha)
But, a little birdy told me about the "Fill 'er full o water and stick 'er in the Freezer" trick......
So for anyone who has cried over dinted header pipes (like me) or doubts the efficacy of the dark science behind the wise old bikers who tried this in the first place.........here's the exact same section of pipe after freezing in the kitchen overnight.
103233
WOW huh! :D(y)🍺 Not perfect, but bloody close enough I say. (Tears of joy followed)
Anyway, Wheels and Fork legs are next cab off the rank.........stay tuned.
Discussion Starter #55
The head is still waiting patiently in line for some attention (seems it's far more patient than it's owner) at the shop, so we continue our focus on other things....
The Fork tubes got a clean with degreaser and will get further cleaning and sanding before I paint them black.
The wheels were next.....
Bugger me. I applaud and respect ANYONE who can do a tyre change on the trail with those bloody little Tyre Levers they say are great for a trail tool kit. Blood and busted knuckles everywhere and that was from the safety of my garage! In the end, as I wasn't concerned about the Tube or the old knobbies, I resorted to the biggest flat blade screwdriver I had to get the leverage needed to get the old rubber up and over the rim. I've seen guys make it look sooo easy! No doubt old hard rubber (10%) and my shithouse technique (90%) played a part. :unsure:
103250
Once the rubber was off I noticed this crack in the rear rim.......My plan originally was to clean these up and paint black and see if I could polish up the spokes. Yes, very labour intensive but just my time.......but this has given me pause to consider other options..........The crack is all the way through the rim edge but stops at the bottom of the bead part of the rim. (In fact, it looks like there's another one forming nearby) So my considerations are, given that the bike will NOT do much dirt or enduro riding moving forward, that I;
1. Do nothing, just clean and paint
2. Get it welded, then clean and paint (I've heard welding can soften/brittle other parts of the rim around the weld, but as above, it's likely the bike will ride 99% tar moving forward)
3. Buy new Excel Outer Rims only and new Spoke set and re-lace to the OEM hubs......(from what I can see that'll cost about AUD$750 for new Front and Rear, materials only) Not a cost I was planning on, but shit, new rims look so fuckn good hey ;) - The more i think about it, the more I'm considering treating myself and the old girl to a new set of Excel Goodness.... :)
I know what i'd do if Budget was not an issue, and I'm sure budget blowing out by 10-50% is the norm on many projects, but I'm still considering what to do.........?
103251
103252
In the end, I'll probably wait and hear what the guys say about the Head, then make a call on whether it makes sense to go for new wheels.
Here's hoping they say that the head will cost very little to clean up and I can divert that cash to Wheels! :)
(Pray to the Motorbike Gods for me)
Discussion Starter #56
Ok, it's Friday! You bloody bewdy! :)
Just a quick update on progress......
The rim is back at the same shop who did the head. Spoke to Greg Ball who said he's welded plenty of his rims and never had troubles, so that's that. OEM rims will be repaired/cleaned/painted.
The spoke nipples are totally seized, so I purchased new S.S Excel Spoke sets that fit the OEM Hub and just need the Rim Holes drilled to suit the bigger nipple. Apparently an 8.1mm countersink drill is the go.....good luck finding one of those things online. Looks like this will be an interesting retrofit........
The frame has had some progress, with the seat hoop arriving and (after much umm'ing and ahh'ing) being installed, it's turned out alright! :D
From this
103304
to this
103305
Then this
103306
And finally this....
103307
103302
103303
The welds weren't perfect (some were MUCH better than others)......but they're pretty solid and after some grinding its looking ok. As I said I'm still trying to get the hang of the gasless mig, Wire speed, Amperage, etc depending on job thickness etc. I know they're not the best and notorious for splutter, but for the amount of welding I do it's not worth having a bottle account anymore.
So the frame is getting pretty close to being ready for a sand and Primer Coat.......maybe this weekend! :)
The fork legs and lower triple clamp have also been sanded and will possibly also get a primer coat if the Paint Gods are smiling. Hope you all have a bloody awesome weekend. :)
Discussion Starter #57
Oh, P.S - The head is back after a refresh..... look at this beauty.....
From this......
103308
To this.........
103309
How could I forget that?????? :)
Discussion Starter #58
Hi all,
well, it's been a month since my last post and things have slowed somewhat, but I suppose when you get to the Prep/Prime/Paint stage that's to be expected.......so we're still making progress, albeit slower than before.
The rear rim has been repaired (welded where it was cracked) and the wheels de-laced, cleaned, etch primed and painted black, then re-laced with new S.S Excel Spoke sets. The hub's also got a polish and paint touch up where needed.
103555
103556
103557
They now need tru-ing and tightening and I'm waiting for a torque wrench to arrive to get that job done. (the front rim has a MASSIVE wobble, so it'll be an interesting First Attempt at Tru-ing a wheel for me. I hear a patient approach is essential. :)
The interesting thing about this part of the build has been drilling the Nipple Holes in the OEM Rims to accept the new wider diameter Excel nipples. Only a few mm bigger than stock but the HOLE ANGLE had to be correct and inside the RIM needed to be bevelled to allow the nipple head to seat.......but still some of the nipple heads don't currently contact 100% of the rim, due to the shape of the pressed area around the spoke hole. It'll be interesting to see if the spokes want to bend at all as the nipple is tightened. We'll see I suppose. (the below is an example of one of the "worst" nipple heads, even thought they're only in there a bit more than finger tight at present, you can see how it won't seat fully on it's bevelled face - I was worried about taking TOO MUCH meat from the other side of the hole to get the side shown to "sit down" further)
103562
The Frame has also has a prep/prime/paint and is ready for all the bit's n pieces to start going back on! (Yay)
103558
103559
I also moved my Spray activity to the back shed. MUCH Better idea without having to worry so much about overspray.
And here she is coming back together........
103561
Next steps are
1. Strip and Spray the tank Honda Red
2. Polish engine fins
3. Prep/prime/paint engine black
4. Put the engine all back together and back on the bike. (a few weeks (months?) of fun there for sure..........)
One question for the experienced out there.........I had the tank on the bike the other day and was wondering, when fuel starts running low, how is Petrol supposed to get from the Right Hand Side of a steel Tank, UP AND OVER the main Frame to the Petcock on the left hand side? From the shape of my tank, it looks like a fair amount of fuel will get stuck in the RHS fin? The below doesn't show it super clear, but you can see there is a 30-40mm step up between the L & R sides of the tank, which obviously acts as a weir when the bike sits vertical.
103560
There's no outlet on the RHS for a crossover line......but I'm assuming not all tanks have them and wondering if tipping the bike left and right in turns is enough to slosh fuel into the LHS. If not, I'm wondering if I should put one in before painting? (P.S - Yes, the tank is a Wuhan replica of a Honda CB tank that I got cheap cause it had a small dint in it that I'll fix before painting, so it could be a case of poor design.....but I'm not so sure.).......OR is is supposed to be this way and the "weir" is essentially the level of the "reserve" tank????
Any clarification is appreciated and thanks in advance.
This isn't going to be much help, my Hornet has the same issue.
I lose about a gallon of fuel to the right hand side of the tank, why Honda chose not to fit a second tap I'll never know, but it is what it is. Just as well it returns 60 mpg or I'd be filling up every other day.
Frame looks very nice btw.
  • Like
Reactions: Burgo72
Discussion Starter #60
Thanks Steveo, understood. Maybe their thinking was you run it till it stops, then just lean it flat over to the LHS for a few seconds and "Viola!" another 60Miles range, instantly, for Free! haha. Thanks for the compliment on the frame mate, the camera is obviously flattering, but it looks ok in the flesh. ;)
41 - 60 of 70 Posts
