Mods: this should probably be in "technical" forum please feel free to cover my mistake and move itas you see fit...
Got the (sticking advancer) idea while writing reply to my other thread.,I sprayed it with wd 40 and ran it out on an empty backroad. it still breaks up at 7,000 rpm. I changed my grip and make sure the throttle is wtfo.in top, it breaks up pretty bad, BUT if I back off slightly I pick up a few more rpm(by stock tach and ear)back home the brand new plug electrode( the bent one ) is light gray.I figure the main jet is too lean. Here's the specs: carbs: stock original keihins,
air filters: uni foam sock hangin nekkid in the breeze.
pipes: stock cl high pipes, muffler cut off at the muffler , jc whitney internal baffle installed in each straight pie,6" chrome straight extenstions to trim whitney baffle and hacksawed original pipes.
Do you guys have any jetting recommendations ?What do you run with open pipes and pod filters?
"Some things are still a mystery to me,while others are much too clear..."
Edited by - ace on Jul 29 2006 01:19:05 AM
Edited by - ace on Jul 29 2006 01:23:38 AM
