Hi! New poster and first time bike restorer. Thanks in advance for going easy on me.
Last fall I obtained a 75 CB550. When I began to disassemble, it had two fuel lines going into a petcock with two outlets. I took it at face value and am now reconnecting the fuel lines to a new, identical petcock. Here's the problem:
Before installing the tank/petcock and fuel lines that are upstream from the filters, I thought I'd test it out by putting some fuel in the tank and opening the petcock into a container, to check the flow. When I set the petcock to 'On', fuel flows freely out of one of the lines, but not the other. When I switch to 'Res' or 'Reserve', fuel doesn't come out of either line. Based on the original setup, this does not make sense to me.
Can anyone assist with an explanation of why fuel doesn't come out of both lines, in the 'On' setting? Does a single fuel line supply all four carbs? Does it do so through a single inlet on the carb rack, or two? Do I need a 'T'? Or is the second inlet, near the #4 cylinder actually for vacuum?
Thanks for educating this newbie.
