1 - 2 of 2 Posts
hi,im currently looking at a super clean 77 xs750,it's actualy 2 bikes one super clean stock bike + one ratty parts bike.i can probably get both for 700$.do any of you guys have any input in this model???any issues with the inline 3 ?i also understand it has a driveshaft insted of a chain,any issues there?? im riding a cb360 now and would not mind a bigger bike.any input from you guys is much appreciated.cheers
-jason
biggest problem is the fuel pecocks
get the pingel adapter plates and screw a normal on/off/reserve petcock
the factory ones fail and will not turn off the gas
then the crank cases fill with gas
and many of these had their bottom ends/cranks/cases ruined when they were run with engine oil wrecked by the fuel
parts are expensive and there isn't a lot of aftermarket stuff for them
you don't have to order the stock fuel hand over t's from yamaha
you can strip the plastic off the originals and reuse them with orings out of a standard kit
they are heavy but neat engines/drivelines just the same
some have second gear problems
by now the wiring harness connectors are ready to turn into crayons
1 - 2 of 2 Posts
