141 - 152 of 152 Posts
Hi,
this is Lukas from Germany. I also wrote you an private message, but I Think you did not see it yet.
I fortuitously found your thread in Google about the pod filters on Mikuni VM22 carbs on a 1979 Suzuki GS 550.
I am also building up a GS550 and it was very interesting for me to see your pictures that with normal low cost pod filters the air passages are blocked / could be blocked. So I decided to buy the K&N pod filters shown in your thread.
And now my question:
Could you please tell me your carb settings with the K&N installed? Main jet size, pilot jet, Needle,..?
That would be very great and a big support for me and my project
Thank you.
Best regards
Lukas
I will be amazed if the response is anything other then the stock jets just adjusted properly. If your K&N felt filters are properly oiled you haven't really changed anything that will alter the fuel to air ratio appreciably.
If you also made huge exhaust system changes at the same time possibly, but you have not indicated that.
add:
K&N air filters don't actually pound 50% more air into your carburetor then a brand new clean OEM paper filter, their claim to fame is that they trap and hold dirt more efficiently and while doing so their ability to allow air flow is less affected. Properly serviced, they hold more dirt, are impervious to the affects of water and still pass air where a dirty paper filter would clog up and starve your motor for air.
Discussion Starter · #142 · (Edited)
Hi,
Thank you.
Best regards
Lukas
Honestly, it has been so long, I don't recall exactly. My latest notes indicate 100 and 102.5 mains in (up from OEM 80's), stock pilots (with adjustments made on the air and fuel screws) for idle, and the needles raised 1 or two notches.. But the carbs have been off several times since then, and I don't remember if I made any adjustments.
What I will say is that there is NO MAGIC number, or formula for tuning carbs. There are too many variables. The filters are just a small part. The exhaust system is a large factor. Variations in the engine, temperature, elevation, humidity all play a role. And here in the US, our government has determined that it is a good idea for the corn farmers to sell surplus corn to the oil companies instead of exporting it to places that have more need. Consequently the gas we get has 10-15% ethanol in it, wich not only wreaks havoc on rubber seals in old carbs, but I have found it also requires a slight bump in jet settings to compensate.
Tuning carbs is a process!
First step is to make sure all your boots are good and the o-rings sealing them to the cylinder head are good.
Second step, and THIS IS IMPORTANT, is a valve lash adjustment. Particularly on this bike because the valve lash adjustment interval is every 3000 miles and the lash spec is stupid small (like .03 - .08 mm).
Third step, if you have points is to adjust them and be sure you have good and equal spark on all four cylinders. (I installed electronic ignition, higher ohm coils, and a relay to feed the coils directly from the battery to ensure good spark)
Fourth is to do a compression test.
Don't even think about your carbs before the first 4 steps are done and any issues are resolved.
5. Remove and clean the carbs, all passages and all the brass need to be cleaned thoroughly. Clean out all the holes on the emulsion tubes.
6. These bikes are really sensitive to carb synchronization. Do a bench sync when you have the carbs off. (The manual tells you how to do it) You will need a good set of syncro gauges or mercury sticks later to perform a running sync
7. Get the idle right. Start with 1 turn out on the fuel screws (the ones closer to the engine, and 2 turns on the air screws. There is a procedure to get the idles right, and it does involve a bit of "feel" and know-how. But basically you set the idle speed to about 1100, and adjust the air screw on the first carb to get the highest idle speed. If this happens with the air screw less than 1 turn out, you need to bump the fuel screw out a bit. Reset the idle speed and repeat on the next carb. Once you have a good even idle you can move on.
8. I set the main jets next. This requires a long empty road and do a crap ton of "plug chops". Run the bike at wide open throttle down the road through the first few gears and shut off the ignition with the bike in the upper RPM range and the throttle open. Coast to the side of the road and pull the spark plugs and read them. White means you need a larger jet, black means you need a smaller jet and tan is pretty close. Look for variations between the cylinders.
9. Once you have the main jet sorted out you can adjust the needle height. I do this with a combination of setting the height so I can roll the throttle on without bogging or stumbling, and doing a few partial throttle plug chops to verify the needle setting.
10. Once all this is done, it is time to do a running synchronization of the carbs.
You need to go into this with the realization that you will be removing the carbs many times during the process. This is the old school way.....without a dyno.
Discussion Starter · #143 ·
So, I’ve been trying to get rid of a peculiar handling issue. I’m getting some chatter during tight 180 degree turns, fully leaned over and when transitioning from braking to throttle. It only happens in those long carousel type turns and I have to be on the edge of the tire. I can minimize it by scooting up on the tank and putting more weight on the front. I’ve played with compression (emulators), put as heavy an oil as I can for rebound, played with preload and air pressure. I’ve gotten close, but it’s still there. So my latest attempt at a solution.... Tarozzi to the rescue! I am hoping that the issue is a flex problem, not a damping issue.
104431
104432
Discussion Starter · #145 ·
Put on some squiggly balloon tractor tires on it...
you have too much grip up front.
That’s the same trouble shooting line of thinking as turning up the radio to cure bad noises in the car. The only one that works with is covering up the annoying squeal coming from the passenger seat.....
Don’t know why that last pic showed up sideways. Let’s see if it comes out right if I rotate it and post it....
104437
  • Like
Reactions: jcw
Discussion Starter · #146 ·
Yep. That worked. Actually the fork brace solved a couple issues I didn't even consider issues. One was a tendency for the front wheel to weave ever so slightly when going down a straight road at even throttle. I attributed that to the large 19" front wheel tracking irregularities. It was a tiny improvement, but immediately noticeable. Another immediate improvement (which wasn't unexpected) was how solid it feels when stuffing it into a curve. But the main issue was the chatter and the front trying to fold up when leaned over in tight switchback turns. I can hit a bump mid-turn and get the tire to skip, but instead of chattering and folding, it stays on line.... Very happy camper.
Gonna go out and try again, tomorrow.
104470
104471
Discussion Starter · #148 ·
I’m doing a thing…..
Electric fan Gauge Magnifying glass Eyewear Automotive lighting
Gauge Motor vehicle Automotive tire Automotive lighting Motorcycle
Discussion Starter · #150 ·
That looks good. What AFR guage is that and where did you get it?
It is an AEM gauge. I ordered one that I thought was AEM from Amazon, but when I got it, I discovered that it was a knock off, so I packed it right back up. Then I ordered a genuine one from Summit Racing
  • Helpful
Reactions: Tinsnips
Flex anywhere in the wheel bearings, axle or misalignment in the lower fork legs will make your bike wiggle and brakes drag during the moment of flex. Newer motorcycles are fitted with a fatter stronger axle to do virtually the same thing as the fork brace does on RSU forks, it attempts to keep everything in align when the assembly is under severe stress. That flex and the resultant brake drag is far easier to detect on a dirt bike where speeds are relatively low and the momentary stress is much higher when you drive your front wheel into a rock or log obstacle with sufficient force to compress the fork springs. Most are familiar with the wiggle, few are aware about the brake issue.
Discussion Starter · #152 ·
Once I get it all sorted out and installed, I’ll post progress photos. This process encompassed a couple other things that needed to be done like updating the fuse box from glass fuses to blades and re painting the exhaust….. which now has an O2 bung welded in.
  • Like
Reactions: Tinsnips
