Anti reversion cones would serve a very similar function as megaphones. Impractical for most V8's to run megs.
Parks...you mean a "poppit" valve? Already been done...kind of hard to control valve timing if exhaust pressure has to open the valve. One might think that inertia would lift the reed and create a vacume behind it...not so...some positive pressure will always be required to lift the reed...you wouldn't want that positive pressure between the reed and the exhaust valve. Better to let that inertia expend itself in an open pipe pulling a negative pressure behind it.
