Amateur Manx 40M preparation
25077 Views 130 Replies 9 Participants Last post by  Mike 40M
Starting a thread about my -59 Manx. Should never had bought it 3 years ago, if it had not been raced quite successfully by a friend of mine. We used to ride together on our road Nortons, he on an Atlas and I had a Dommi 99. Learnt a lot from him about race lines and how to stay alive on public roads. For some reasons, I have to get it going asap. Started collecting new bits for it a year ago. In january I started to take it apart. Also got new parts needed. As a motorcycle in pieces takes a lot of space, I started to assemble it yesterday. Frame in good shape, only minor scratches in the paint. Swingarm bushes ok, now greased. Head bearings Ok.
First thing to do was rear mudguard in bad shape., replaced with a new. I think a -59 should have alloy rear mudguard, but as I'll try to set it up as it was when my friend raced it, it got another fibreglass one. Advice and critics welcome.
Bicycle fork Auto part Bicycle frame Chassis Machine
  • Like
Reactions: 1
21 - 40 of 131 Posts
When inserting gearbox with righthand engine plate in place, it hits frame about 3/8 before it meets the engine plate.
Auto part Bumper Tire Rim Wheel
Bumper Technology Automotive exterior Auto part
OK got it. how much do you need to remove for clearance?
If its not much say an 1/8 maybe 3/16 then option ;-
1 / Heat the frame in the troubled area till red , put a 1 inch bar across the and give it a clout (can't believe I am advising this).
Or
2 / Angle grind and clean off excess from the gearbox.
or
3 / A little of both (this is most likely what you will need to do.
Same issue on a Petty frame!
Auto part
Mixing new and old often bring problems.
Gearbox will take some time. To make the workshop tidier, I will put some other things in place. Continued with forks (thanks jalsteve). For readers not familiar with fork assembly I'll show the special tools I've made. To compress fork just an ordinary luggage tie down. A rod with a long nut in one end that can be attached to the damper rod. When damper rod is up, I use a piece of metal with a milled slot. When rod is up, I slide it under the lock nut. Then it's just to replace the rod lifting tool with the fork top nut (and washer).
Engine Auto part Vehicle Automotive engine part Suspension
To make something easy for a change turned and fitted alloy barends. Then tried out flyscreen fittings. Have to figure out best top attachment. Will probably be tyraps and a piece of rubber. Booked same racenumber as it had last time. Saves me trouble of putting on a new number. Sent result of med test to federation, paid for licence.
Then continued with slimming gearbox. After a bit of milling found that counterboring 4mm for the offending Allen screw was needed. Tried it in place once again. Close but not enough. Turned a taper on the Allen head and did a little more alloy filing. Result is .031 clearance to frame.:)
Auto part Tool accessory Machine
Auto part Metal
Not much new today. Got a good idea from a guy who builds and races a homemade gasturbine landspeed bike. Use a cheesehead screw instead of the protrouding Allen screw. Only problem is that I live in a metric country where a slotted 5/16UNC x 1 is almost as rare as hens teeth. Found Gearbox could not be moved fully rear. Hit fhe nut for the adjuster stay. Some grinding fixed that. Hopefully last problem with gearbox is that upper 9/16 bolt don't fit. Seems they drilled it from both sides and not in line. Did not have right size tool, so gave it to a mechanic who will fix it early next week.
Did a simple job for a change, put on the seat.
Started with the wheels. Front no problems at all, looked fine. Rear wheel, except some cobweb, needs regreasing of the bearings.
Questions to the experts:
Rear brake, there is only one spring. Should it be two and in that case, is it a Manx specific spring?
There is no bearing seals at all in the rear wheel, is that correct?
You will have to wait for Jalsteve to come along to enlighten you on the rear hub, I'm not familiar with that new fangled modern stuff. As for the cheese head screw, Im not sure what you would gain from that. You would need to countersink the bolt hole to recess the cheese head and you could do that with allen bolt. It looks as though there is enough meat there, but if it clears now, I would think .030 is sufficient.
Hoping that jalsteve will have time to spread his wisdom on rear hub parts, I contnued with gearbox installation. Spent yesterday evening filing LH engine plate to accomodate that fat and heavy TTI-box.
Now the gearbox and LH engine plate is in place. Shortened the bottom gearbox stud 4mm, so now it's possible to take gearbox in and out without raising and/or lowering engine. Norton should have done that mod themselves. As a final touch I drilled a 2mm hole in the gearbox and a washer with a tab also drilled 2 mm. So now I can lockwire engine and gearbox drain plugs.
Only tricky part in gearbox assembly is the top rear engine bolt. To get washer and nut in place below the magneto and behind magneto chain covers is a bit problematic.
Washer was put in place with help of a small magnet. For the nut a thin plastic glove with nut inside (on left hand thumb) worked surpricingly well. Blurry on picture.
Vehicle Auto part Motor vehicle Engine Spoke
Springs - There are 3 on the rear brake plate. The shoes have two as normal, one at the cam and one at the pivot. The third is fitted behind the brake operating arm BUT often this one is left off. The brake shoe springs are heavy gauge and not like those you would find on a road bike. Andy Molnar can supply, its probably best to replace anyway.
Have a really close look around all the spoke holes for cracks and ESPECIALLY inside the hub were the large cast spokes meet the outer casting as they are prone to crack. If you find a crack the hub is scrap, don't be tempted to weld, and don't be temped to use.
Auto part Rim Wheel Automotive wheel system Rotor
The problematic top engine bolt - just get a piece of bar (you can use Dural) say 50mm x 20mm x 12.5 (1/2 thick), drill a hole at one end and tap 3/8" 26tpi replace the nut with this. the length allows you to easily fit and its hidden so doesn't affect the way the bike looks. This was a period mod.
Not surprised, some more parts needed. While waiting put on some small parts. Seat, front mudguard, handlebar grips, tacho drive cable, gearbox sprocket, rear sprocket and a sharkfin.
The torque stay in place. Front bolt replaced, some fool had used a full threaded bolt. Had to make a special nut with a spigot at rear end of it.
Been too busy with my job as eventing crosscountry course designer, preparing seven different courses with around eighty obstacles for next weekend.
Takes to much time from the Manx.
Started clutch work. Finally decided to use an ordinary Manx clutch. Got an almost new Newby clutch really cheap, but decided to use it on next winter build, a Norton caféracer.
Can't remember about lubrication of the clutch roller bearing between centre and basket. Help please.
Some photos of a a Manx rear brake plate. Replica but exactly as original.
Looking at the out side of the brake plate you will note a small peg on the plate near the brake arm this is the anchor for an external brake arm spring. And on the photo of the inside note the heavy brake shoe springs.
Auto part Disc brake Vehicle brake Brake Automotive wheel system
Auto part Audio equipment Clutch Automotive tire Automotive lighting
The clutch roller bearings are a point of weakness. There are 15 1/4x1/4 rollers held in a pressed steel cage, a period mod was to replace with 50 1/4x1/4 rollers which gives better support to the chain wheel (basket) and helps it run more true with less movement. Lubricate with a HM lithium non fluid grease, you don't need lots as you will be removing the plates and giving them a clean after every race and can add a little grease at that time?
Which clutch are you using? The Burman type with inserts in the chain wheel or AMC with a friction back plate? They are both good clutches if its original Manx clutch (centre with have 6 bolts) please don't use for racing they are rare today and you will destroy it. Buy and modified a road AMC clutch just narrow it down for 4 plates. Or you can be similar from Andover Norton. Run the primary with about 25mm of up and down movement (that's an easy inch!!!). As the engine warn up it heats the gearbox and engine plates so centre of clutch to crank centre increases. I always run the bike around at low rpm and get all nice an hot then stop and check the tension of the primary chain, when hot there must be a little play. I have seen gearbox main shafts snap in race conditions and drive side main bearing wrecked through over tight chains. Belts are more forgiving.
Ref bearing seals - Correct there are no seals as the wheel spacers or brake plates collars act as deflectors. Just pack with a good quality LM grease.
Sad to say, have been busy with other things. Not much done to the Manx. My neighbour calls it the mailorder bike. Just because all delivery vans and lorries that come with small and big parcels.
Next week nothing will be done to it. Then I'll do the rear wheel, get primary drive in line and try to fix a leak in left fork leg.
The original (?) clutch is a mysterious thing to me.
Clutch part Gear Auto part Rotor Bicycle part
Notice the spring screws with 1/4" square holes. Basket and pressure plate lightened. No steel cage but filled with a lot of rollers. 6 Allen screws. Friction plates and centre different size of "splines" than other Nortons. Steel plates probably usual size. Sadly it had a hard life, centre much worn. Will use an Andover clutch.
Some small things done. Replaced rubber mount for float bowl and made a gear lever.
Yep that's an original clutch with a modified centre. Usually the extra slots in the hub were done as the old slots get badly notched. The 1/4 x 1/4 50 roller conversion is a common mod. The chain wheel is standard Manx, the copper plate was applied to protect the basket during the hardening process, road clutches don't get this treatment. All Manx clutches have square key bolts and the springs should be square section wire.
Just go through it and rebuild so its serviceable and put it in the bikes heritage box.
Clutch springs round section, think original did not last for 9 years of hard racing. Friend borrowed an excavator from me, in return took new clutch parts to machine them as old one. Nice to have friends with CNC-machines, when you only have manual machines. Race scrutineers nowadays might have some opinions on some original parts, so some parts had to be made. Alloy footrests done and threaded 7/16 BSC. Since the old Arrgardh gearbox had a reverse gearlever, a temporary gearlever is made. If the bike is ever is running again, I'll decide what length it shall have and make a period looking one. The TTI-box was ordered with that in mind, so it will be the usual 1st up, the rest down as all my other English bikes have. Today made a .6mm shim under engine sprocket. Primary chain is now quite inline.
As nearest Manx I know of is some 150 miles away, there are things that I can't figure out.
What does bolt or stud holding front of chainguard look like?
Since most of the oil and breather lines was a real mess when I got the bike, advice please. That upper line to oil tank is return and lower is supply is probably right but the rest?
Have to make a tool for retainer holding rear wheel bearing. Difficult to figure out diameter for the 4 holes. Of course a hammerhappy cretin had been there.
I hate lockwiring. Not the wiring but drilling the holes. Bolts is easy compared to nuts. Worst is nuts in oil fittings. Finally bought some tiny endmills which made it a lot easier. Starting with an endmill and then changed to a drill. Now the drill breaks when going out instead of when starting. Managed to make 5 holes whith only one broken drill. New record :)
Not much room to lockwire oil lines on a Manx. Luckily had some forceps which made it easy.
Auto part Engine Automotive engine part
Yes the temporary gearlever is hideous.
McIntosh Racing sells that stud, grommet and nut for the chainguard, but there must be someone closer to you. His parts listings don't include photos, but there are some closeups of that side of the engine in his photo gallery that would give you an idea of what it looks like.
its a stud with 5/16 BSCY thread at one end and a 1/4 bscy (same tpi as 1/4 BSF). There is a grommet that fits into the chainguard and top hat washer / sleeve arrangement - the top hat is drilled out 1/4" and fits into the grommet. To get the chain guard alignment correct fit a nut on the 1/4" section of the stud this is used as a backing nut and locates the chain guard. the final bit is a large washers and another nut which fits on the out side to hold the guard in place - will take a photo tomorrow.
What to do if the thread is knackered, new 3/8 thread cut into the old hole (was 5/16). Narrow a bolt head with the correct thread and drill centre to 1/4bsf stud needs to be long enough to be able to move the position of the guard to be centre over the chain.
As original with stepped stud 5/16 and 1/4 threads. Belt drive primary but it's the same mounting type.
Thanks, will use old chainguard with dents and welds as it is. Dents from broken chain at IOM junior TT at last lap in -63. Like to keep some parts of its history.
Old engine was rethreaded to 3/8. As you told before about chain tensioon cold vs. hot, I see the reason for the design. Easy to make it except for the knurling (lousy at making 'em).
What about rear mounting?
The rear mount is simple. There should be a flat bracket on the rear curve of the chain guard, it will have a largish hole in it which takes a grommet. With the chain mounted up front this bracket should positioned behind the frame gusset plate and there should be a hole in the frame 1/4. Make a dowel to fit in the grommet with1/4 bore and bolt the frame via the hole in the gusset plate. Note you must fit grommets or the chain guard with be in tension and will crack.
