There is quite a lot of room inside the Manx head in the plug location. To check clearance position the piston at TDC and measure with a Vernier (depth) at the low side of the spark plug hole, then measure the overall plug length (the bit that goes in the motor). You need 40thou min clearance. If you mark on the plug where the electrode is welded ensure this is at the top (12 o'clock) when tight. Personally I would avoid protruding plugs. Sometimes its worth getting on eBay and search for some Champion N54R or harder, KLG FE295's buy new old stock. B9 or B10EGV are fine, perhaps later iridium plugs around the 9 or 10 range.
The gardener is simple to set up. set the fuel height to approx 1/3 of throttle opening. With the fuel on and the throttle open to about 1/3 the fuel should gush out of the central fuel jet. If not the fuel height is too low. Setting the needle can be more problematic as there are many needles, different lengths and chamfer so you may need to experiment. with what you have, screw the needle all the way in onto the last indexing notch, then turn out 5 turns. Run the bike to till hot and if the bike spits on 2/3rds throttle on load = weak, turn the needle out one full turn and run the bike again and so on.
I dislike the Gardener float they've always flooded or leaked, maybe I have been unlucky. I prefer the matchbox.
Starting your Manx with a Gardener = roll back onto compression, fuel on and open the throttle to 1/3 point and count to 3 if the engine is cold, 1 if hot. This floods the inlet tract. Then bump. Easy. My 92mm Bore engine runs with a 42mm Gardiner and it will idle when hot! Not a good idea really (as the engine knocks the hell out of itself) but it does prove what a great carb they are.
By the way you can run your Gardener without a float chamber if you want, they are happy to run that way too.
