1 - 17 of 17 Posts
It must be some sort of big Mono class bike. I like the straight line down through the head intakes.
From what I can tell it is info on the BMR-Suzuki Supermono race bike that used a heavily modified Suzuki DR800 motor with Apfelbeck head and twin crank, hence the interest in the machine from the French Suzuki DR group you linked the images from.
http://www.bmr-team.de/
quote:European Season Ended
Our European season ended with a very nice 21yr old German lady named Katja Poensgen winning the championship riding a BMR-Suzuki. She achieved this by winning 4 out of seven races with one second place & 2 DNFs.
The BMR-Suzuki she rode is a very interesting tool. It may have started life as a DR800 motor but that was long ago & far away! It's creator is Rupert Bainzel, and apart from a lot of bottom-end work, the motor features a machined-from-the-solid top end, with an Apfelbeck type of cylinder head where the valves are arranged radially, with exhaust & inlet ports placed diagonally. As you can imagine, this calls for some hairy machining of cams, they are conically ground. It's watercooled and fuel-injected & gives over 90BHP from 741cc at 8000 & peaks at something like 9300rpm. Since this represents a BMEP figure of something in the order of 215psi it is a considerable achievement.
Of course, this didn't happen overnight, it's taken some years to develop it to the present pitch and I know that Rupert won't even think about how much it's cost!
Engine
Based on DR Big Single Cylinder Four-Stroke
Capacity
741cc
Valves
4-Radial
Spark Plugs
3
Camshafts
Twin, Conical, External Belt Driven
Carburation
Downdraught Electronic Fuel-Injection
Power
94bhp @ 8100rpm
Chassis
Aero-Space Quality Tube And Plate Steel Frame
Italian Supermono Championship, wins Constructor Championship and Title, racer M. Lucchiari
Damn. As a machinist and tinkerer I aspire to this.
quote:Originally posted by Geeto67
stupid question: why two con-rods and counter rotating cranks on a single cylinder?
They do that on overly large diameter pistons to stop them skewing in the bore.
Discussion Starter #12
Impressive increase in peak bhp/rpm went from 54bhp/6600rpm, 94bhp/8100rpm.
The early French article hinted at the crank + piston being destroyed by the increase in piston velocity in bench testing. So the skewing must cause the piston the lock in the bore and go boom.
I wonder though if a deeper or more robust piston skirt would have solved that. Yes it would have increased reciprocating mass, but maybe not as much rotating mass as twin cranks? Plus that piston looks heavy with two wristpins and the rod mass has to account for something!
It is impressive nevertheless!
I would expect the counter rotating cranks to act as a balancer setup as well, eliminating most primary imbalance leaving you with just the up and down from the rods and piston?
hoof: honda xr250 and bigger post 84. once even the 200 was RFVC.
twin cranks are ok provided balances and weight are dead accurate to each other. much discrepancy and those big gear couplings will get backlash thatwill have one eat the other then it's cocked piston time. makes more sense than a balanceshaft if done properly.
leaves plenty of room for good diameter tunnel ports.
finally saw my mates espada last week. inlets between cam tunnels miura donk swung 90 degrees. i kissed it's hatch glass.
1 - 17 of 17 Posts
