This is probably a very basic issue but I don't think I am doing it right. I just rebuilt the front brake on my CB750K5. I have a new piston and seal with new calipers. I filled the master cylinder and pumped the brake, then loosened the bleeder valve until some fluid came out, then tightened the bleeder valve with the brake lever pulled in. I repeated this process and filled the reservoir again.
I still have a bunch of play in the brake lever. All in all it works much better but it is by no means tight. It is not at all like my MX disk.
Am I bleeding the air correctly?
Thanks, again.
Mut
Thanks, again.
Mut
