aaron, did you really have brake fade into 3 with that brake?? i used to have a little fade on the 350 with it, but id think on a 100lb lighter bike, it shouldnt be a problem. mike cooked the drum brown when he had it. its a little surprising that it fades, especially since id think you wouldnt be hauling that bike down anywhere but that corner. you sould check for heat. i know that mike morse told me that brake was good to something like 300 degrees. you obviously know what you need to do to those compounds to make them work. i can get you the numbers for the compounds if you have questions about it to mike morse. but id doubt its a heat fade. especially with that scoop.
later
me
later
me
