For those of you trying to decide on a front brake for a 200-350cc vintage racer....consider the CB450...again.
I've been working on a few of them this week. Fine piece of work they are. The alloy used in the hub is noticably different from older/other hubs. Fine grain, harder to machine, less prone to corrosion, polishes nicer. A VERY well built and sturdy hub. No more braking power than the 305, but if bike weight is an issue it's a stronger hub. Iron bores for the bearings and the cams. Shame no one makes custom shoes for them...you could probably squeak another few mm of width out of them without running over the stock hub liner.
So..before you buy that expensive alloy front rim...think about how many spoke holes....the 450 hub needs 40. The 305 is 36 holes.
