1 - 20 of 77 Posts
Mr. Bill "Big" Johnson has finally bugged me enough and I'm building my own bike. I have my provisional novice ticket, just finished my first race at Beaverun on Bill's bike, and I plan to race this bike (350/500GP) at VIR in March 2010 to get my license. I'll update my progress and probably be asking a lot of advice and looking for parts. I'm local in Maryland.
I'm pretty sure it's a 1974 CL350. I think it was raced in Canada?
I have 35mm forks from a CB350F. I'm looking for good triple trees. Any suggestions/offers?
I have a good condition 2LS front drum from a T500 (Titan Cobra?). I found a few hairlines that need attention. I am looking for someone to weld the T500 drum - Any help?
I'm rebuilding the carbs now (115 main and #38 slow jet). I can't get the two smallest jets out of either carb. Any suggestions? Anyone selling a pair?
New lightweight sprockets on the way from Sprocket Specialists (17/33) to go with a new D.I.D. 520 chain.
New Woodcraft split clip-ons and 1/4-turn throttle ordered.
I'm hoping to run a PVL so I don't have to bother with points and battery. Any PVLs for sale?
Discussion Starter #2
How do I attach pics to this thread? Can I link to my FB pics?
use the reply to topic button at the bottom of the window. click the little mountain looking button at the window top. insert the url for the image in between the img tags that appear. there is a how to in the faq section. youll need to have the images hosted someplace. like photobucket or something like that.
you can not link to a fb image.
For the T500 drum - make sure what you're looking at are cracks and not casting marks. T500 hubs DO crack but they also came from the factory with casting marks that look like cracks. In my experience, when a T500 hub fails, you can see a strong light through the cracks.
Contact Eric Kalamaja at Sundial Moto Sport and ask him who he would recommend to weld a T500 hub. Use the 0416 number posted on his site - that's his cell and you'll get a faster response.
http://www.sundialmotosport.com/
Or you could always buy a "new" hub from ebay although I'd ask for some pictures of the inner hub surface first before I'd spend any money on a hub:
http://cgi.ebay.com/ebaymotors/Suzuki-T500-show-quality-front-wheel-hub-68-75_W0QQitemZ350251136776QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item518c983708&_trksid=p4506.c0.m245
Also, it's worth posting the link to Vintage Brakes views on the various drums out there:
http://www.vintagebrake.com/drumspec.htm
Jim
you should be able to link a facebook image, i do it one other forums, if the album is not private, right click and copy image address in facebook and paste and bracket correctly here.
like this, tell me if you can't see the tick.
huh.....i wasnt able to. hmmm.....
christian, i was going to mention eric kalamaja at sundial motorsports when you posted over on the wera board. but there are probably people here who can weld that up for you properly too. well, i know there are. and like i said, be sure they are cracks. like was mentioned above. though having it welded prior for reinforcement never hurts.
Discussion Starter #7
The "before" pics:
Discussion Starter #8
I like the high mount exhaust right now. Not sure how my left calf will like it later!
Discussion Starter #9
Got engine out last night. Sure looks 35 years old:
Can't wait to powdercoat this:
T500 drum:
Crack along the bottom of the gusset where it meets the drum?:
Hairline like this at almost every gusset:
Discussion Starter #10
Thanks Liam!
Joe
I think all the Baltimore guys should be running animal print seat covers in their first season, especially if they're part of CheeseyPants racing
Oh, you may not have heard but ClanceyPants got changed to CheeseyPants up at Mosport while you were out searching doggedly for cheese slices for your burgers and hot dogs
Discussion Starter #15
Update:
Focusing on the engine for a while. Looks pretty good, but I have little experience. Replacing the crank case with one without ugly welds. Each piece will get a good media blasting and the bottom bits some hi-temp paint. New timing chain and tensioner coming. New 1+ bore and pistons will also help.
Discussion Starter #16
Thanks to Joe Traino for the electronic ignition - who got it from Bill Johnson. I won't be running a PVL (money going into engine) and I won't have to deal with points.
Discussion Starter #17
This is supposed to be an early 70s Honda 350F (Four).
I took the forks off it. They are 35mm and they are stamped with "341." I really need to know what forks they are so I can order new springs.
341 is the part number code for a CB750. Is there a caliper mount on both lower fork legs? CB350 only had mounts on the left lower. Is the front wheel a 19"? The Cb350 had an 18. I think it looks like a CB550 frame. It had a 35mm fork and is a good one to use, too.
The frame should have a VIN on the steering stem that starts with the model designation.
Discussion Starter #19
These forks had a single-piston caliper on the left fork only. I'm not sure if it is an 18" or 19" rim. I'll check next time I'm at the shop. I'll check the VIN too. Thanks!
The 550 and 750 both had a single caliper but had provision for a second caliper on the other leg. The 350's right leg only has a fender mount bosses.
1 - 20 of 77 Posts
