1 - 8 of 8 Posts
This is where I'm at on my bike right now
[/img]
I just installed the 900RR frontend, I'm waiting for the swingarm should be here Tuesday it's off a 2000 600 F4.
I'm making the seat base out of balsa, fiberglass and epoxy.
I made a pan to cover the subframe, then I made a seat pan that I could cover to make the seat.
[/img]
[/img]
I haven't ever done upholstery before I'm going to use a four way stretch vinyl called Allsport.
I think it's what they use on jet ski seats.
Getting the foam shaped to the right contour will be the hard part.
[/img]
One other thing I was wondering was has anyone ever installed spoked rims on an F model.
And why can't I get my pics to show up in my post.
There, how's that? BANDIT
Edited by - BANDIT on Dec 09 2006 4:38:11 PM
If you think the jackstands are sketchy you wouldn't have liked the tow strap swing I had it hanging from.
I am going to make a trim piece that fits on the area where the sidecover used to be.
I'm not sure how it will end up. Once I have the seat covered I can make the other parts to fit.
The seat will sit as it is now .I'm not going to mold the two together. I will just cover the seat pan and install fastners in the bottom that hold it on the subframe.
Edited by - lnewman on Dec 10 2006 10:30:04 AM
Discussion Starter · #7 ·
Thats the stock swingarm
I bought a 600 F4i swingarm I just need to fit it.
I'm going to keep the comstar wheels on it so I will have to put different bearings in the wheels.
I will have to make some spacers to center the wheel in the new swingarm.
I'm not sure about the swingarm pivot bolt, It's probanly not the same diameter so I will have to change those bearings too.
1 - 8 of 8 Posts
