1 - 6 of 6 Posts
Can I use Stock CBR clipons, on a cl350, a clipons pretty universal?
Sure why not, just wrap about 20mm of electrical tape around the forks (A roll a side should do it) and the CBR clipons will fit just fine, as a bonus they'll be nicely dampened and you wont feel any vibes through them, steering responsivness may by a little mushy though...................
If it was a serious question, then I feel obliged to add DON'T do the above, just a little concerned that if you had to ask you might try it.
yeah about 12-20mm depending on model and year. I don't think CBR reflects a single model but more like 100 different year and model combos.
Yes, you can...but will need to have an appropriate spacer machined to take up the difference in fork tube diameter. Having said that, unless you have access to a lathe and can do the work yourself, you would be better off just buying something that will actually fit without all the extra time and expense.
1 - 6 of 6 Posts
