1 - 9 of 9 Posts
Hello gents,
I have a Mikuni VM carb, and one of the towers that holds the float has been broken. I guess that's what you could call it, the pin that retains the float goes through these two little aluminum towers.
Anyway, I'd like to glue the tower back together with epoxy. The repair will be below float level, so it'll be immersed in gasoline. The repair won't be under any stress, though. Has anyone had any experience with an epoxy adhesive used in this way, or have any better ideas?
I suppose having it TIG welded would be the best way to repair it, but I'd like to avoid the cost of having that done.
have you been talking to frank smith?? when e pulled apart one of his carbs last year, it had the same thing goin on. ut the float was fucked. it was all crooked and whacked and wouldnt work right.
I've never used JBWeld when a repair item is in direct contact to fuel
so I cannot say it will not work
I have used "Devcon" in carbs, fuel tanks, and ports
for sure it works good and lasts a long time
I believe you can still get it
perhaps in a round white tray from your local GM parts department
that particular break of the Mikuni VM can be a tough one
I've scrapped several of them for that reason
I got turned on to Devcon reading about Grumpy Jenkins and other notable NHRA guys
it wouldn't surprise me for there to be something light years better
Devcon has been on the market for a loooooong time
good luck
as far as I know jbweld is fuel proof. I think it even says so on the tube. I have used it to repair a leaking triumph petcock and it worked really well.
cool, good to know if I'm ever in a tight spot
have you ever used any of that insane glue they use to secure golf club heads onto those tiny shafts?
I don't think it is fuel proof but that is some crazy strong stuff
jewelers use it instead of jewelry glue
for pearls and things like that
jb will probabley work if you shape it to help support/brace the stick. marine-tex (no relation to our esteemed texy) is excellent as well for these kinds of mickey-mouse repairs.
-parks
do you know who supplies Marine-Tex?
I'd like to have some, that stuff is great to sealing porous castings.
GM paid me several times to seal SBC and BBC castings that seeped from time to time
and that is what they supplied
I guess I could check with a GM parts place
1 - 9 of 9 Posts
