1 - 3 of 3 Posts
Ok folks, need some help with a friends '75 CB200. He's cleaned the carbs, replaced the throttle cable and given the bike a typical tune up, plugs points etc.
When he set the idle speed to run correctly at warm engine, it won't idle cold. When he sets it to idle cold it runs at 2500 rpm warm.
He's in SanFran so I can't tell you much else, but I know he did what he did thoroughly and by the Clymers manual.
Any helpful suggestions would be appreciated. Thanks...
FR
Did he check the float heights? I had a similar problem, only a little more drastic, on my 75 cb200 and that was what wound up being the problem.
1 - 3 of 3 Posts
