In the laundry list of things that are keeping my CB200 from running is now the engine wont start. It started before and ran fine but now it will only turnover, and if it did start, it would idle poorly for a few seconds and then die out. When it did start and idled, one of two things would happen when I open up the throttle: 1) it would either rev or 2) die out. The times that it would rev i'll take it for a spin around the block and when i slow down and pull the clutch lever, the engine would idle and the die out. I haven't touch anything on the bike except for the electrical when i put on clubman bars, and that's the battery decided not to charge but that's another issue. Does anyone have any experience with this? Is it probable that this can be a throttle issue?
