I have extra slipper tensioners for CB350 if anyone needs one. They are teflon sandwiched in steel. You do need to relieve the cam tunnel in the head to put them in, which can be done on a mill or with an airtool, which ever you have. They are $125.00 plus $5 for shipping. You don't need to split the cases to put it in, only if you replace the chain.
The chain is the Tsubaki CB750 SOHC cam chain. Joe was saying you have to grind off the rubber, but his was the first one I have ever had to do that on in 6 years. Those chains are about $35 and are endless. You can split it an duse a CB450 master link, but endless is better.
If you want a tensioner, e-mail me directly
[email protected].
I only looked here cause Joe made me.
Chris
