I need to pull the engine from the junk 350-4 so it can go to a new home. There are no carbs, pipes etc. on it. There is something sticking out of the front of the case that goes thru the frame rails, looks like an oil filter (?)that maybe just comes off.
What is the best way short of a torch to get the motor out? Any particular pitfalls to watch for? It looks like maybe motor mounts need to be removed?
There was a tread a while ago about pulling the motor from a 350F--is that the same as a 350 Four?
The new owner and I thank you.
