1 - 5 of 5 Posts
I'm running out of gas on right side carb only, can see thru clear filter. I open gas cap and still seems air bound. ANy ideas? Needle valve, maybe?
Thanks for the advice. It appears that for some reason if the filter is higher than the float it is causing a problem. I beleive I have this sorted out for now.
New to the forum and like what I see so far. I hope to be racing June in Loudon. If anyone is reading - see you there.
fill out your profile.
do you mean july 4th (uscra)?
1 - 5 of 5 Posts
