1 - 4 of 4 Posts
Anyone happen to know if 32mm VM32 Mikuni roundslides will fit in the factory manifolds of a CB350 twin? I know a lot of people run them, but I've never heard of any manifold issues. The diameter of the neck of the Mikunis seems to be about 1mm larger than the factory CV carbs. Maybe I can lube 'em up and cram 'em in?
Thanks fellas,
As it turns out, they fit great. I was test fitting them on an old parts motor I have, and the intake boots were hard as a rock. They slip right into the nice supple boots on my bike. The only gripe I have is that the little rib that is molded into the boots to fit into a groove in the carb neck doesn't quite line up on the Mikunis. I'll just clamp em down German-style (gütentight).
1 - 4 of 4 Posts
