Hi, I've got a 72 cb350 w/cv carbs. It starts up and
idles ok in the driveway, but after I run it down the
road a few times it will quit every time I pull in the
clutch. It also kind of jerks and boggs down in lower
rpms, say below 3000 or so. but after it winds up it
really does run pretty strong. but I can't ride it cause
i have to kickstart it at ever stop sign! This much I know:
The valves are adjusted correctly, the timing according to
a light is good although when set staticly, the light says it
is 5 or 6 degrees off. everything I can inspect visually in
the carbs is clear. Does anyone have any suggestions?
Thanks
Kirk
Thanks
Kirk
