CB350F Fork conversion
11805 Views 21 Replies 11 Participants Last post by  robertob
Hi guys,
I'm new to the forum. I have a CB350F (disk front) and would like to change out the forks for something more modern. What is the process here? I'd like newer forks with clip on bars etc (more cafe style) What forks are interchangable with the CB350F? What is the process re break calipers on newer forks...are all the fitings standard?
Thanks
Izzy
21 - 22 of 22 Posts
The good calipers (and their matching fork mounts) unfortunately only work with newer, thinner, lighter 5-bolt rotors which, also unfortunately, only come on ugly Comstar rims or, on some CB750ks and CB650s, as a single disc spoked wheel.
I have never seen a dual-disc, spoked wheel that works with the 5mm thick late model rotors and matching calipers. Oh, and most of them are 19" so you will have to search before finding an 18" wheel to match your stocker. This applies to the above too.
The best calipers for the above swap are the ones on 1980 CB750fs because they are dual-piston and will still clear spokes.
Here's a fun, geeky experiment not entirely proven to work: FZ750 floater discs have the same bolt pattern as a late 70s CB750k spoke hub. Dual floating discs on an 18" spoke wheel = modern sweetness. The unresolved issue is the caliper mounts/which calipers to use....probably WAYYY too much brake in the end, anyway.
Honda go sideways!
Edited by - krapfever on Feb 12 2007 6:57:34 PM
Hey that's cool - I'll have to check it out and see how things match up.
Honda go sideways!
21 - 22 of 22 Posts
