OK guys, I have found a good head with all valvetrain + cam that came from a 74 cb750K. I'm hoping to clean it up and swap it on. Just in case, can anyone suggest a good place to buy valve guides if I need to replace them? How about a better-than-stock clutch? I found a Barnett kevlar clutch kit on eBay, what do y'all think? Also looking for a rear sprocket thats 1-2 teeth larger than stock, all I can seem to find are stock replacements. A good jet kit as well, bike has header and pod filters right now, and could use more fuel. I will be posting pics of whatever I end up doing to keep everyone entertained.
Thanks! <img src=icon_smile_tongue.gif border=0 align=middle>
sprocket specalists will hook you up with any size sprocket you need, even in aluminum and drilled for weight (totally worth it in looks alone if you ask me). Google them.
I have had barnett clutches in cb750s before, I happen to like them but I am also a drag racer at heart and ride like one. A lot of people I talk to find the whole barnett setup too heavy in the lever action for the street. The solution is to either replace the clutch lever with a modern adjustible one (check ebay for universial ones) or to run barnett springs with stock fiber plates. I have this setup in my daily rider and find it awsome for stop light to stop light use but find it makes an awful noise when cold and slips a little off the line when I am wanking on it.
Basic head rebuild parts should be available from honda. Cycle ex has a basic head work deal for $385 that I happen to think is a bargain:
http://www.cyclexchange.net/Engine Parts Page.htm
HOWN ABOVE IS ONE OF OUR STREET FIGHTER HEADS.
LABOR:
DISASSEMBLE HEAD
GLASS BEAD PORTS
PRESS OUT VALVE GUIDES
STREET PORT THE HEAD (DRAG RACERS WILL REQUIRE MORE WORK)
SURFACE BOTH SIDES OF THE HEAD
INSTALL NEW VALVE GUIDES
REAM GUIDES
GRIND VALVES (NEW OR USED)
MULTI ANGLE VALVE JOB
CLEAN AND REASSEMBLE
DEPENDING ON CARBS, PIPES ETC. PORTED HEADS CAN GIVE YOU UP TO 10% ADDITIONAL POWER. WE ALWAYS TRY TO HAVE HEADS IN STOCK ON A EXCHANGE BASIS. Labor Starting At $ 385.00 , Parts are Extra, Of Course
As long as you are doing the top end, spend the money for a cam (approx $200) they will even install it for you. I would definatly do their high perfromance valve springs and heavy duty chain ($60 for the springs, $40 for the chain). A new tensioner while you are in there is not a bad idea either ($60). But I could spend you money for you all day long.
check out cycle exchange's whole website tons of cb750 stuff, most of it chopper but a lot of it cool and can be used on a cafe bike.
