1 - 20 of 24 Posts
So I cleaned my carbs for the first time. I used a small safety pin to clear out the main and slow jets. I put everything back together and started it up, it immediately revved to 10,000 with no throttle at all. Did i mess the jets up by sticking the pin in them? I did pick up some size 90 jets, can i replace the stock size 88 without too much of a problem? thanks for any advice you might have...
to rev to 10k, you have a pretty good chance that you have cables routed wrong and the throttles in the carbs aren't closing enough. how many carbs are on your hypothetical bike?
what happens in November btw?
Discussion Starter · #6 ·
i thought that my carb slides may have gotten screwed up, i couldn't figure out how the needle, spring, cable, and slide interact with each other, i've never had them apart before, they just came undone this time, i thought i had them back together correctly, oh, i have a cb200 btw.
Discussion Starter · #7 ·
Have you checked for air leaks around the intake?
Discussion Starter · #18 ·
hey pinche, you wouldn't own a puffy shirt or two, would you?
thanks for the help folks, i'll report back after some brow ridge scratching and poking with sticks...
Discussion Starter · #19 ·
What kind of carbs are they?
You should have no problem finding a diagram online (search Google images).
1 - 20 of 24 Posts
