1 - 3 of 3 Posts
I'm picking up a bike that has had the engine painted with silver spray paint. I want to strip all this off. Will any ordinay paint and varnish stripper be ok? What should I use???
Thanks!
Sandblasting using glass beads works great for cylinders, Paint stripper for auto paint should work ok for the other engine items. I would test a small item before going crazy with the entire engine. For my own use, I fire up my sandblaster...
if you are going the stripper route, use aircraft remover made by klean strip. that stuff works wonders. i like to use a sand blaster if i can, but a lot of my parts on the RD, it just wasn't an option. good luck
1 - 3 of 3 Posts
