That is what I figured, but did not want to have wires exposed...Do you have any pics of your bars?quote:
looks like it would be a real bear to try and run wires through a clubman bar. which is why i didnt even try when i had em on my bike. just zip tie the wires a couple of times on the bar.
Do not worry. Modern bikes have the wires/ harnesses runing on the outside. You will be fine. Get some electric tape ( black ) and cover your cables if not done so. Then use plastic tie downs to afix the cables to the bar following the natural flow of the cables. Your stock wires should be long enough. Unless there is a specific issue with your particular bike.quote:
Check this out:quote:
1974 CB 750
