My 78 750 Super Sport engine is now on my workbench with the head and cylinders off. I have a damaged camshaft, cradle, rocker arms and valve guides. I acquired an earlier model K head which has been refreshed with new guides, seals and valve re-seating. Do I need to replace the cylinders as well when I do the head swap? I can't see any difference between the K and F2 cylinders. Is there something I am missing? Sometimes something obvious goes right by me and I need it pointed out. I also have a set of cylinders from a K model which I planned on using, but if I can keep the original cylinder, I would prefer that. Do the pistons need to be replaced as well with the K model, or will the f2 pistons work without hitting anything?
Thanks, Roy
Thanks, Roy
