1 - 8 of 8 Posts
I have a 6V flasher unit on my bike that is a 3 wire unit. I bought another flasher unit (same specs) that is a 2 wire unit. Do you see any reason why I can't switch to the 2 wire unit?
The 3rd pin is for the signal light in the dash (or "P" for pilot light). I take it you have a single light in the dash for the indicators (IE: not an individual light for each side)?
You should be able to wire this pin to the 2nd pin on the relay (if my logic is correct.....)
1 - 8 of 8 Posts
