1 - 7 of 7 Posts
I am thinking that I would like to consider a girder front end on a cafe style 2 stroke single. Maybe the look of the older Brit stuff with the Villiers 2 strokes, but I would start with a Jap enduro as the basis. What does anybody know about girder front suspensions? Not springers, I hate springers.
HackA? What have you got laying around?
the only thing I currently have in a girder is a 1935 Indian Sport Scout unit, it's been molested so I removed the huge stem and fitted a 1 incher to it, doubt I'll use it on the panhead it's on right now but it does look good there
funny thing is a guy had it fitted to a brit cafe bike and welded BSA axle clamp ends to make it accept a 190mm Goldie hub
the work was solid enough but ugly so I cut it all off and redrilled thru axle holes
I had been looking at these two and slept at the wheel
http://cgi.ebay.com/ebaymotors/ws/e...STRK:MEWA:IT&viewitem=&item=320228483386&rd=1
http://cgi.ebay.com/ebaymotors/ws/e...STRK:MEWA:IT&viewitem=&item=320228480175&rd=1
the old girders are cool to look at, they work ok
but one made with modern bearings which can easily be serviced by replacement
well they are nice
I've started one for a project here that is built that way, no bushing pressing/reaming/fitting required
and using a dual air chamber over hydraulic shock instead of just a spring
I do like girders and didn't snag either of the posted ones because I was busy in the shop
anyhow, I'll dig and see if I'm forgetting but some are definitely better than others
this sport scout unit is neat but like many period girders
to overhaul it...... is an expensive pita because of how it's made and how all the bushed pivoting areas work
you have to replace the studs, which are not simple hardware but actually a part
and bushings which also are not a standard bushing but actually a part
then ream or hone to fit
a rambling side note
Gambler, back when CK Spurlock owned it
made the first modern girder that used double angular contact bearings
they worked very well and economical to produce although the bearings weren't cheap
I don't really know anything about the relative sizes of girders, but having seen pictures of some of them on the early BSA singles, they might look right on a 2 stroke single.
Any idea how rigid they are under side loads? Most of th ones I have seen seem to be triangulated nicely fore and aft for braking forces, but are only 2 dimensional for side loads. I like the looks of the ones built up from tubular stock.
the original prototype of the confederate wraith used a girder with the shock and spring hidden inside the neck (actually the neck was the shock as it was fluid filled). JT is a freaking genius for designing that.
you are asking the right questions to indicate your eyes are well calibrated to real world function of these forks
There have been various girder makers thru the years, and some have worked much better than others
some English makers were Brampton, Castle, Monarch (I think) and a few others
some of them were notoriously weak as far as side loads and some would break "hammer links"
that is what the English call the 4 dammits that control the up and down motion
if you look at many you can see why...... some are just plain flimsy
I think one found in the links I posted struck me as being very frail as far as the hammer links are concerned
and if they strong enough but still thin, the shear loads will be phenomenally high
then when you start looking at how they are bushed and pivoted
it becomes much easier to tell what's for real and what's weak as puppy piss
yeah the tubular girders are great and very light
the better designs are quite strong
poke about at some of the Indian girders, like the sport scout, and various girders found on many English bikes
a girder off a smaller Indian, like a 250-ish small bike
might be just what you need
stay away from the DKW-HD 165 rubber band stamped steel ones
they are kinda laughable
Discussion Starter · #6 ·
well, I have ridden enough race bikes to be concerned about side deflection. But this would just be on a fun street bike. How hard would it be to just lay out a pattern and have some tubular girder legs welded up? Since I don't have a project bike yet to start with, I'll keep looking around.
cake walk and really nothing much to it
My thinking is to use high grade "stripper or shoulder" bolts
good bearings precisely fit
and when a bearing wears
replace it and keep on going
the "hammer links" need to be robust enough to carry a moderate size bearing anyhow
I am thinking a 6200 series DA contact bearing should be quite adequate although the next size down (0.500" ID) is likely overkill
the 6200 series has a 0.625" bore
beats the daylights out of having to replace 8 inch studs and oilite bushings because both will wear at nearly equal rates
1 - 7 of 7 Posts
