Will a '76 Gl1000 (goldwing) front wheel fit on a '75 Cb750? I know they have dual discs and aluminum rims. What size are they (19 or 18)? Thanks, Jimmy
Most wheels from all of the Japanese Companies from the 70's to the mid 80's should fit. I would first find wheels that have the same tire size. Just make sure that the spacing is correct between the fork and wheel. If the axle bolt is different all you have to do is change the wheel bearings to the correct size. (You probaly have to change them anyway if you get the wheel from the salvage yard. I will even bet that the brake rotor from your CB will fit.In the end try it!
Hope this helps,
JohnyKZ
Edited by - JohnnyKZ1000A on Apr 25 2006 2:20:48 PM
Thanks for the reply. I found out from some guys on the SOHC forums that it will fit. The whole Gl front end will fit, so now I'm looking for one of those (they have 2mm larger tubes, alloy rim, dual discs). Jimmy
1 - 3 of 3 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
