1 - 7 of 7 Posts
Hi All it's Rich the shop teacher. we are looking for a tachometer and were wondering what some of you all run? We would like to get away from the cable drive one. We have an electronic ignition and a battery eliminator one of the podtronics ones with a seprate capasitor. does any one have any sugestions for us? if so what is the model# and make
Thanks
The web site is up and should be updated this weekend
Richie
most tachs are 12volts, or are stepped down in voltage. if youre running a system like that, you need a self powered tach, or need to figure out a way to power one. i had talked about getting the voltage to a vfr tacc, and using it, but youd have to have a battery to run it. pain. the only other thing would be a schitzu or one of the other really expensive tachs made overseas.
cable tachs work fine.
· Premium Member
Yeah the cable tachs are hard to beat for reliability and simplicity. They are a bit heavy for a race bike, but for a street bike I think they look kind of old school cool.
And the Honda cable tachs I've found that work are usually dead on accurate.
What you need is a nice custom mount to make it look good.
But yeah...if you gotta have a electronic tach...Scitsu makes a real nice over priced tach (about $200+). Works off a rechargable battery, very light, very accurate. But you have to charge it and it's kind of picky about the way you operate it.
· Premium Member
check out auto meter pro cycle tachs. i run one on my cb350 racer, reads to 14000 rpm, and looks damn cool. can be had for less than $200.00
texy
"bitches!"
1 - 7 of 7 Posts
