i have most of the parts i need for the brake upgrade. the only part that i'm lacking is a banjo bolt to feed both calipers. as far as i can tell, i need to put both hoses on the same spot with a longer banjo bolt and a crush washer in between them. does this bolt have to have to holes drilled in it or just one?
