1 - 6 of 6 Posts
I replaced all of my turn signals with newer and more smaller signals, The fuses are blowing and I went back through the bike to see if there were any wiring issues and there werent! I want to know if I would be able to replace the old fuse box with a newer up-to-date box that use the plastic fuses rather than the old AGX glass bus fuses??????where would I get such a box??? and would that make a difference??? thanks
Arctic Cat ATV part number 0530-003 is a fuse block with space for four fuses (you supply the terminals; use female spade connectors) for about 15 bucks. search this site also for the cheapo fuse fix (same thing almost without the fancy plastic box).
1 - 6 of 6 Posts
