I built a drop dead gorgeous CB160 cafe racer and the carburation is driving me nuts. It has a stepped header exhaust with Dunstall style mufflers, slightly raised compression and stock carbs with pods or open (makes no difference).
At idle is is way too rich to the point that air screws adjustment makes no difference. Carbs have been cleaned multiple times in the sonic tank. I have sprayed cleaner through all the drillings and compared the results with spare carbs.
The exhaust have a large diameter perforated tube inside a megaphone shaped outer shell and a flat piece of perf plate half way down the main tube to deflect sound waves and attenuate the sound. The mufflers have an awesome, mellow sound but are much larger diameter than teh headers so I made up some stepped adapters to make it all work.
End result is that the bike starts on the first push of the button without any choke and as it warms up it gets wet and soggy and revs drop because it is so rich and the plugs are black and wet.
Normally I would try smaller pilot jets but not surprisingly, jets for these old bikes are not readily available in any size especially smaller than stock. I am pretty sure it would run without the airscrews so that leaves me limited ways to lean it out.
I will remove the center plate obstruction in the muffler but that's unlikely to make much difference and I could possibly drill larger air holes in the emulsion tube part of the pilot jet or I could throw the carbs away and buy a pair of VM22 Mikuni carbs (or copies) and jet from scratch for each circuit.
I have boxes of larger Keihin carbs and stock carbs and jets for Mikuni and Keihn carbs but I think I am running out of ideas.
Any ideas?
Any ideas?
