How to Quiet my Cafe Racer Down
1747 Views 14 Replies 7 Participants Last post by  brad black
Hello!
(This is my first time posting here) but long time Cafe Racer enthusiast.
I'm looking to reduce the noise of my 2002 Susuki Savage 650 with the Ryca CS-1 Cafe Racer Kit by about 80% if possible.
Can anyone point me in the right direction on where to buy a Baffle or something to put inside of my Reverse Cone to reduce the majority of the noise that the bike makes? Not sure on which path to take or which size would be the right fit.
Reason being I live in an apartment and my neighbors cannot handle the noise of my bike.
Thanks!
-Matteo
1 - 15 of 15 Posts
This page has info on how I did the custom baffles on one of my bikes:
Get some perforated baffle tube, muffler packing materials, and zip ties. You'll need access to a machinist/fabricator if you can't weld/braze yourself.
Otherwise, the simplest solution is to just walk the bike out of the apartment complex and start it up at the exit.
What you are looking for is a stock exhaust. Then you can tell the neighbours to pound salt because you are completely legal.
Loud and leg burning, maybe they should have looked at the bike more and the computer less. Cad programs should have an "are you fucking kidding" that pops up when the user does something stupid.
Did you put some decent rubber on yours?
You are a thoughtful neighbor... Or you have been threatened haha
Megaphones are used to make things louder. If you want quiet, you're already headed the wrong direction.
If you must use one because you like the shape, it has to be full of sound damping material like fiberglass. Don't use stainless steel wool, it doesn't do jack to attenuate sound. Basically you want a perforated tube running the length of the pipe, with fiberglass stuffed in the area around it. But with a megaphone shape you lose a lot because the packing has to be at least ~20mm thick around the pipe to really do much.
I don't know what your bike looks like but if you truly want it quiet, ditch the megaphone and buy a cylindrical shaped muffler with packing in it. And don't go overboard on how big the inner pipe is, the added restriction of a smaller pipe doens' tmake nearly as much difference in power as people will have you believe. Trust me, and straight through pipe will have significantly less restriction than a stock muffler.
Hello!
Thanks!
-Matteo
I also just want it to be around 80% Quieter in general, anyone have any other options or info?
Thanks!
Thanks foe the response - I don't have access to a Welder but will look into some of these options more. How much did this quiet your bike down % wise? Thanks
Significantly... to elaborate:
The baffles that came with the exhaust were exceptionally tiny. I got the bike running well on open megaphone, but it was stupid loud. The baffles I made Significantly reduced the decibels, so now its probably 50%? Louder than stock.
Supertrapp style exhaust, where you stack in as many washer things as you want to make it quiet or not.
  • Like
Reactions: 1
if you still have the original muffler, put it back on. simple.
a customer bought in one of these stamped sort of baffles (it had a large end plate) to jam into the short megaphone on the ducati below.
104664
104665
i squashed and welded the leading end shut, wrapped most of it in sheet metal and flattened the stupid 4 or so remaining open louvres down quite a bit, and this was the difference it made. baffle in, then baffle out.
desmodog is a professional in exhaust design, so he knows what's he's talking about. you need another muffler.
  • Like
Reactions: 1
Not anymore, I retired yesterday! :geek: Now I'm trying to decide if I should start searching for an M900 or 1100Evo Monster as a new project bike... or sell everything and buy a toy car. But I digress.
Anyway, yeah, if it were me I'd use a different muffler. The reasons why get into a long description involving things the OP probably doesn't care about so I'll skip it.
Another thing people are doing to quiet things down is to put a honeycomb shaped substrate thingie in the pipe(s). Those are pretty much just converters with no coating on them by the way. They do broadband attenuation and might be easier to use than a baffle you put into the muffler.
  • Like
Reactions: 4
Congratulations on retirement. Well planned to have it start with summer.
  • Like
Reactions: 1
1 - 15 of 15 Posts
