I need alot of help. Im new and I cant figure out what I did. My Bike '78 cb400t - So... I got home from work all excited to switch out my new indicators after reading replies from you excellent people on how to mount them. I take off the original indicator snip the wires (with the ignition off) and I begin to try and figure out which wire is the ground, b/c both wires are the same, by touching both leads to the new indicator and then turning on the bike with the blinker switch on...nothing with the front. I snip the rear lamps and those work!!! I go back to the front, still nothing. What gives? At this point I look to see if there is a busted fuse, I doubt it cause that wouldn't make and sense being that the other lights are working but just to make sure I start taking them out, finding that nothing is wrong and replacing them from where they came. Just at that point the gauge cluster, the head lamp and all indicators TURN OFF. Pretty pissed at this point. I think its the battery so I test it. 12v FULL CHARGE! What's Going On HERE?!?!?!? I replaced the relay with a brand new one... and I cant think of anything else. HELLLLLLLLLLP!!!!
