so my cl360 was running fairly well. sometimes making little popping noises that make me think the timing needs to be adjusted (is that right?) but other than that everything seemed good. then a few days ago she started idling really high (was at 1.2 now at 1.8 or 2 or so) so i put my hand behind the pipes and they both are spitting out air like they should but the left pipe is cold air and the right pipe is warm. pulling the plug on the left pipe hardly affects the idle at all while pulling the right plug kills it.
i didn't see a spark on the left plug when i held it against the fins but i could feel a charge zapping me a little bit through the rubber...
so what gives? where do i need to start to fix this?
thanks in advance,
johnny
thanks in advance,
johnny
