Running the sl350 carbs on the 175. Rebuilt them with new parts. runs great on one side, other side is shit. symptoms:
1. If the float level is too low, I don't get any gas. If the float level is where it should be, I get gas, but I also get gas from the overflow. not good. And when I do raise the float level to get more gas, it runs great, but only over 5k rpm, when the carb finally kicks in.
2. So at lower rpms, say 4k, it's still running on one cylinder.
3. I took the carb apart and blasted everyhting. all holes are clear. I am running the 102 main jets
4. I'm baffled. Been through the carb over and over. Give me a new tack here, or a new idea. As I said, one side is great.
5. Yes, I did switch plug wires, that ain't it. I got plenty of spark. And yes, I checekd the valves. It's this one carb, but something just isnt right.
6. It's odd that the float level on the other side seems to be perfect, with the tang in the right place, but on the bad side, the tang needs to be bent down (or up) quite a bit to get the needle to seat. Maybe I grabbed a wrong needle.
arrrrggghh.
scott
arrrrggghh.
scott
