41 - 53 of 53 Posts
Yea, a small oil cooler couldn't hurt though, I have the mechanical timing advance and pickup coil from an old honda 3-wheeler, and the cdi, think all I need is a stator made for a cdi, stator on the kz is only made for charging I think
Discussion Starter #42
You could always use a DC cdi. Lots of GY6 based scooters use this. Beware some use an AC cdi that requires a stator, but alot use the DC unit (on DC units the two pin connector usually only has one wire...). But, being that the KZ is a streetbike and has a battery, you could use the DC cdi running off of your charging system. No promises that the advance curve is right, but there are adjustable units that change where the advance starts for cheap.
I've thought about the dc cdi, but I figure if I am going to run the kz/klt 250 crank, I might as well run the stator from 1 of the motors too, I should be able to wire a cdi up to the stator
- - - Updated - - -
every 4 valve dual cam head I find on ebay is liquid cooled, I can not find an air/oil cooled 1
Discussion Starter #45
I move the frame around the other day. Does that count?
haha, I got this 1 200 running, been riding it around, doesnt really seem to have enough power for the stock 15/40 sprockets, will be awhile before I can afford to buy the 300ex piston and bayou top end, probably go with the lakota top end for the better cam when I can afford it lol
- - - Updated - - -
Discussion Starter #47
I hope to get back on it this year. I have been building a new shed/shop/moving a garage to my place. So hopefully i will have facilities to do more soon.
I may end building a few odd and end bits for these old girls if anyone is interested. Not a whole lot of demand out there though.
May have found a big bore piston to use with the bayou cylinder, kawasaki mule 76mm piston, uses the same wrist pin as a kz250, just not sure if the piston height is right
- - - Updated - - -
Discussion Starter #49
Nice! What model of mule?
Hi
I've also got an old kl250 with failed camshaft. Since both the bearing surface and tappets are heavily scored i suspect oil starvation. Did you ever figure out what caused your carnage?
Would also really appreciate if you got the images working again since I too will probably use a klf300 head instead of original.
Hi
I've also got an old kl250 with failed camshaft. Since both the bearing surface and tappets are heavily scored i suspect oil starvation. Did you ever figure out what cased your carnage?
He hasn't posted in a few months, might be better to send him a pm, it will show up in his personal email.
Hi all, I am in the process of restoring a '79 kl250 and have been reading this thread religiously!
Thinking of doing the swap to a 300 also. Did you ever get a response from the OP in PM's?
Discussion Starter #53
I actually didn't get an email about a PM. I will see if i can find the pics. I actually came back here looking for them :(
41 - 53 of 53 Posts
